Author Topic: posted on 1-1-1970 at 10:00  (Read 29313 times)
0 Members and 8 Guests are viewing this topic.
« Reply #20 on: September 08, 2003, 08:54:45 AM »
Is anyone else getting a post with my avatar at the top of the page with someone elses response???
;eek
« Reply #21 on: September 08, 2003, 10:04:19 AM »
;eek
Yep
Offline Stingraynut
    • www.myvette.20m.com
« Reply #22 on: September 08, 2003, 11:37:32 AM »
Hi Chris, I was going to ask why a post about suspension begins with you raving about chips, how did that get there ?
On the subject of chips, (this’ll make this post win the ‘weirdest post’ of the year !!) -  I read an interesting one on CF where the guy burning the new chip FIRST took the car for a run and logged all the sensor data. From that they had a good idea of what that particular car needed, for instance it was running lean at WOT etc. Seemed like a logical and scientific approach.
Now we’ve had lunch, it’s back to suspension……..
S’nut
Offline Ausrs
« Reply #23 on: September 08, 2003, 12:48:38 PM »
S’nut
that was mike
(86iroc)
he is in czech at the moment but has been learning the chip burning process much of which can be found on the forums of www.thirdgen.org
Offline Stingraynut
« Reply #24 on: September 08, 2003, 12:54:32 PM »
This IS a confusing thread, I see now that it is a quote, thanks AusRs
S’nut
« Reply #25 on: September 11, 2003, 05:27:02 PM »
Originally posted by StingraynutThose tyre sizes from Vette Obsessed – it should be 275 (x 40 x 17) not 245
Well spotted S'nut.  Sorry for the typo guys.
Have you checked the suspension chart link earlier in the thread?
This one: http://www.zr1.net/ZR1_suspension.html
That gives you all the OEM spring rates on all the different model C4's.  If you don't have a readily accesible build sheet or window sticker for your car, you can find out what suspension your car has by checking under the console door and cross checking the option codes.  Among the many codes printed there, one will be the suspension option your car has.
I have heard some guys report their ride has improved by changing shocks - haven't heard about the ones you refer to though.  You can also get the factory Bilsteins revalved as well.
Another (more expensive) option is to install softer springs (like convertible spec springs).
Offline SAVette
« Reply #26 on: September 12, 2003, 12:42:57 PM »
Sorry if this link has been mentioned before in this thread (or any other....) but have you had a look at:
http://corvetteactioncenter.com/tech/c4/susp_chart.html
The whole of http://corvetteactioncenter.com is worth checking out as a matter of fact. The above links should explain some of you questions about the Z51 handling package. Just as an aside, having a look at some of those numbers might help explain why the '84 copped the reputation of having HARD suspension Especially the Z51!
While I'm here, can some please explain to me what advantage you would get from using a bigger rim on the back, but the same size tyres all round. The '84 Z51 package (like mine) had 8.5" rims front with 9.5" rims rear, but it had 255/50VR16 all round. Did it just give you scope for using a bigger tyre if you wanted to or is there some tyre-wall flex techo thing I'm not aware of?
Red '84 CFI
