Author Topic: How to Read, Reply & Send A U2U  (Read 21380 times)
« on: July 16, 2006, 08:43:43 PM »
A couple of people have asked me about the U2U system.  Hope this helps.
First.  What is a U2U?  It is a private message that has been sent to you from another Forum Member.  Only you can see it..[with the exception of the  super administrator who can see everything that happens on the Forum]
So how do you know when you have a U2U?
A message will appear in the top right hand corner of your screen, as can be seen here in Image 1
Image 1
[img=753x516]http://www.splashedpaint.com/cameron/Cam/U2U.jpg[/img]
You simply click on that message and the following Image 2 will appear on your screen.  Once you have read your message, and you decide you would like to reply to the sender, make sure that A the reply is ticked (it should automatically do this) and then click "Submit Changes" B.
Image 2
[img=753x538]http://www.splashedpaint.com/cameron/Cam/U2U%2001.jpg[/img]
The next Image 3 should now appear on your screen.  The message sent to you will be Quoted.  You simply type in your reply C and then click "Send U2U" D
Image 3
[img=751x535]http://www.splashedpaint.com/cameron/Cam/U2U%2003.JPG[/img]
Your private message has now been sent back to the person who sent you one.
Should you want to send a U2U to some one first, simply click on the U2U button which appears at the bottom of each persons post.  Type in the subject title, click on the text field (box), type your message and click send.
Should you want to print these instruction images out for future reference simply move your mouse to the top left corner of each image. Wait a second or two and a series of small Icons will appear.  Click on the one that looks like a printer and follow the prompts.
Forum Admin
« Reply #1 on: July 16, 2006, 11:13:10 PM »
Very time Consuming Cam what you have done
« Reply #2 on: July 17, 2006, 12:49:14 AM »
All in a days work. Thanks Joe.
Offline TriPower
« Reply #3 on: April 15, 2007, 06:48:35 PM »
hi cam are u happy now, how was today, thanks for saterday at steve thompson's place.
steve tripod i mead tripower.
« Reply #4 on: April 15, 2007, 06:52:32 PM »
Well done Steve B.  Now see if you can reply to my U2U.
It was my pleasure to help out.
Today was damm great.  See if you can find the threads that relate to todays breeky run and todays Drags.
Use the "TODAYS POSTS" feature at top of screen
Tripod, yeah right. ;56
