Author Topic: brakes  (Read 11333 times)
brakes
« on: July 16, 2006, 07:05:01 PM »
brakes
« Reply #1 on: July 16, 2006, 07:06:03 PM »
brakes
« Reply #2 on: July 16, 2006, 07:07:02 PM »
brakes
« Reply #3 on: August 31, 2006, 03:28:29 PM »
Brakes
The only to really improve brakes to to go larger in diameter rotors.
While putting alloy calipers and ventet disce with quality pads may improve you are still running the original 11 1/2" rotor diameter.
If you put 14" front & 13 1/2" rear rotors on with 6 piston alloy front calipers with 4 piston alloy rear calipers the brake improvement is extensive.
You can buy these kits as a bolt on no modifications. However due to the larger diameter of the rotors you will have to go to a 18" rim.
It is also recommended that you reface your rear spindles and front hubs to maintain zero runout of the rotors. Original barke master cylinder and booster is retained.
Possible reinforcing of the front lower control arms may be required for extreme brake use.
brakes
« Reply #4 on: August 31, 2006, 03:30:13 PM »
sorry about the typos
top line should read
The only way to really improve brakes is to go to larger diameter rotors.:pinki
brakes
« Reply #5 on: August 31, 2006, 03:42:00 PM »
Fixed the typo Chromie
You may notice a small "edit" button in the top right hand corner of each post you make - you can click on this to open your post up so you can edit it. ;42
brakes
« Reply #6 on: August 31, 2006, 05:17:02 PM »
Vette Obsessed
Thanks for the tip will try to do better as soon as I can pull my typo fingers out of me butt
Yep I now see the edit button
Thank you for the info:}
brakes
« Reply #7 on: August 31, 2006, 05:26:40 PM »
Good dog.  Woof Woof. ;29
