Author Topic: EXHAUST MANIFOLD  (Read 21290 times)
Offline reserved
EXHAUST MANIFOLD
« on: June 25, 2006, 09:04:46 PM »
:b2:an:mmm:grr
I removed my old exhust manifold to fit a new one, went to remove the gasket, but could not find one fitted anywhere, looked in the assembly manual and found that there was no gasket fitted on the 454 motor. I purchased a gasket with the new manifold, my question to the other home mechanics is should I fit a gasket or not.
All sugestion listened to and then possibly ignored.
;41
:P
EXHAUST MANIFOLD
« Reply #1 on: June 25, 2006, 09:26:26 PM »
Dammm.  No gasket. Hmmmmm.  It goes against my grain not to fit one but they must of had a reason for leaving them out.  I have not worked on a big block.
Rat Pack.  Here is a chance for you to finally make your selves usefull.;41
Offline SC
EXHAUST MANIFOLD
« Reply #2 on: June 25, 2006, 10:47:17 PM »
you can use a smear of black silcone it works well as long as the mating surfaces are in perfect condition if not use a gasket, holden 4.2 and 5.0  engines never had gaskets fitted to them either
EXHAUST MANIFOLD
« Reply #3 on: June 26, 2006, 10:12:50 PM »
So reserved, what are you going to do?
Offline reserved
EXHAUST MANIFOLD
« Reply #4 on: June 26, 2006, 10:26:41 PM »
:evil:b2:evil
I am waiting for more input from my fellow big block experts befor I ignore them and probably use the gasket as it can't hurt.
;27;27;27
EXHAUST MANIFOLD
« Reply #5 on: June 26, 2006, 11:50:58 PM »
i have had big blocks in the past and allways used a gasket;42
Offline smokem
EXHAUST MANIFOLD
« Reply #6 on: July 16, 2006, 08:16:21 PM »
Using silicon is fine as SC says . Use good quality to handle heat . Guy I know in Melb. builds high dollar headers never uses gaskets.
STOP ACTING STUPID!
[/i]
EXHAUST MANIFOLD
« Reply #7 on: July 16, 2006, 11:40:14 PM »
I havent got gaskets on mine either! just that silicon stuff!
EXHAUST MANIFOLD
« Reply #8 on: July 17, 2006, 09:00:32 PM »
No big block here but I don't have any gaskets on my extractors.  They were installed using silicon alone by the place that made the pipes and I've since reinstalled them myself with silicon with no leaking issues.
Offline reserved
EXHAUST MANIFOLD
« Reply #9 on: July 17, 2006, 09:14:00 PM »
:mmm :grr :mmm
Thanks for the feedback guys, OK then how do you use it?
A  thin coat (1mm or so) and let it dry befor fitting the manifold, or apply it and try to get the manifold on and correctly tensioned befor the silicon dries
;eek ;40 ;eek
Offline SC
EXHAUST MANIFOLD
« Reply #10 on: July 17, 2006, 09:31:39 PM »
just like you said a thin coat and do it wet you have plenty of time before it skins over tension bolts and your done black silicon 712 is what we use all the time we have never had a failure
Offline reserved
EXHAUST MANIFOLD
« Reply #11 on: July 17, 2006, 09:54:00 PM »
Thanks SC will try it.
;laugh ;43 ;laugh
Offline reserved
EXHAUST MANIFOLD
« Reply #12 on: July 18, 2006, 08:35:35 PM »
;30 :flower :flower ;30
Today I went to
Bunnings, Auto parts, Repco, Luckey exhausts and SBC
Looking for black solicon 712, with no luck
Best I could find was one rated at 320 degrees C
and not recommended for exhausts.
WHERE DO YOU GET IT!
;48
EXHAUST MANIFOLD
« Reply #13 on: July 18, 2006, 08:39:00 PM »
Try CBC Consolidated Bearing Company.  Do you want me to see if I can get some tomorrow and bring it to Hooters.  Assuming that your going of course.
Offline reserved
EXHAUST MANIFOLD
« Reply #14 on: July 18, 2006, 08:55:34 PM »
Cam :luv
Yes please.
;42;43;42
EXHAUST MANIFOLD
« Reply #15 on: July 18, 2006, 09:11:24 PM »
I'll call in and see them on the way to work tomorrow.
EXHAUST MANIFOLD
« Reply #16 on: July 19, 2006, 10:21:46 AM »
Reserved, no luck squire.  They think that the 712 is a Dow Corning product and they only stock Loctite.  Their high temp only goes to 316 Deg C.
We need to find what the temp rating of the 712 is.
I'll make some calls and see what I come up with.
edietd:-
No, dow corning don't have a 712 either.  You should have got a small block.;39
EXHAUST MANIFOLD
« Reply #17 on: July 19, 2006, 11:18:11 AM »
Ok I'm just waiting for some faxs to come in of the data sheets on some of these products.
I also made a call to Scott at Corvette Alterations.
He informed me that with his infrared thermometer gun pointed onto the exhaust manifold his gun goes off the scale and it goes to 500 deg C.
He informed me that if the surfaces are completely flat and smooth with no pits that the "no gasket" is the better option and if they are not flat, the gasket option is the way to go.  He also said to be sure that it is the metal type gasket.
This is only information that I am supplying for your consideration, it is not a recomendation.  It is in no way to say that any other information offerd in this thread is incorrect.
Once the data sheets on the silicones (silastics) come in I'll let you know what they have published.
EXHAUST MANIFOLD
« Reply #18 on: July 19, 2006, 03:17:05 PM »
Mr Reserved.  I have the data sheets on these products.  To much for me to put up here.  I'll bring them with me tonight.
EXHAUST MANIFOLD
« Reply #19 on: July 20, 2006, 01:58:59 PM »
Hey SC.  You said last night that you were going to check if that was 712 or 732.  Come on get your act together. ;48;43
