Author Topic: ITS COMING  (Read 46234 times)
Offline MrPersistent
ITS COMING
« on: May 24, 2006, 05:00:19 AM »
GETTING CLOSE TILT TRAY BOOKED FOR EXAUST SYSTEM TODAY THEN WHEEL ALINEMENT FROM THERE FOLLOWED BY A TEST DRIVE I HOPE FINISH OFF THE WIRING AND A FEW TIDY UPS THEN OFF TO STEVE FOR TRIM (PROBLEM WITH COLOUR KEEPS CHANGING IN THIS COLD WEATHER;41;41;41)WILL POST SOME PICS WHEN I WORK OUT HOW
Miss Daisy[/size]
ITS COMING
« Reply #1 on: May 24, 2006, 11:23:25 AM »
u d better hurry up and get it ready !!! the brekky will be on me mate...only ur first run!;43;43;43
ITS COMING
« Reply #2 on: May 24, 2006, 11:58:47 PM »
Het everyone Jolinari is shouting every breakfast!!!!!!! "the brekky will be on me".   hehehehe
ITS COMING
« Reply #3 on: May 25, 2006, 12:03:32 AM »
HEHEHE;53 Don't worry I will organise a bbq soon (upon my return, end of June) and a run to the blue mountains  ;42
 we will wait for VO
ITS COMING
« Reply #4 on: May 30, 2006, 01:43:46 PM »
Finaly got  car back.  4 days for wheel aline.  Back in garage to continue, ;54;54;54;54;54;54 soon I hope.
Miss Daisy[/size]
ITS COMING
« Reply #5 on: May 30, 2006, 07:21:50 PM »
Hurry up so I can laugh when it comes out on the road in flouro green with purple engine!;:spook:spook;41
Offline MJ427
ITS COMING
« Reply #6 on: May 30, 2006, 10:52:51 PM »
;41
ITS COMING
« Reply #7 on: June 01, 2006, 11:08:19 AM »
Like the speed sign there MJ.  Neat trick.
Wonder what colour MrPersistent's car is this week? ;35
Offline MJ427
ITS COMING
« Reply #8 on: June 01, 2006, 12:12:56 PM »
pink with purple poker dots
ITS COMING
« Reply #9 on: June 01, 2006, 03:05:09 PM »
the motor is orange this week ;41;41;41
Miss Daisy[/size]
ITS COMING
« Reply #10 on: June 01, 2006, 04:05:58 PM »
hey chevy orange aint to bad...........:grr
ITS COMING
« Reply #11 on: June 01, 2006, 06:24:00 PM »
I hear you toyed with the idea of giving the radiator extra straight through, cross flow ventilation.;53;53
ITS COMING
« Reply #12 on: June 01, 2006, 09:10:32 PM »
Bill, another little lesson for ya while I'm here.  Check your U2U message.  It's located in the top right hand corner of your screen.  See if you can reply to it.;42
ITS COMING
« Reply #13 on: June 01, 2006, 11:00:54 PM »
Bill,
Found this in my Haynes Repair Manual.
"With the engine up to running temperature, the ignition disconnected and the throttle wide open put the compression gauge into cylinder No 1.  Crank the engine over at least 4 compression strokes.  The compression should build up quickly in a healthy engine.  Low compression on the first stroke, followed by gradually increasing pressure on successive strokes, indicates worn rings.  A low reading on the first stroke, which does not build up during cranking indicates leaking valves, or a blown head gasket cracked head etc, etc.
In the case of a low reading, add some engine oil down the bore[about three squirts from a plunger type oil can] and crank the motor.  If the compression increases after the oil is added, then the rings are definitely worn.  If the compression does not increase significantly, then leakage is occurring at the valves or in the head and or gasket."
"Pressure should be 150 to 170 psi and minimum of 120psi"
All according to my Haynes manual.
[/align]
ITS COMING
« Reply #14 on: June 02, 2006, 03:11:11 PM »
THANKS CAM ALL IS WELL PROBLEM SORTED THANK GOD ;););)
Miss Daisy[/size]
ITS COMING
« Reply #15 on: June 02, 2006, 06:20:05 PM »
Good news.  Bet that had ya worried.
ITS COMING
« Reply #16 on: June 03, 2006, 09:06:23 PM »
So how about an up date?
ITS COMING
« Reply #17 on: June 04, 2006, 10:47:43 AM »
we want some pics............:b2;eek:23;ay:b4;36
ITS COMING
« Reply #18 on: June 04, 2006, 07:06:43 PM »
THEY ARE COMING ;28;28;28
Miss Daisy[/size]
ITS COMING
« Reply #19 on: June 04, 2006, 07:09:12 PM »
WAS THAT AN UP DATE OR UP YOUR DATE;45;45
Miss Daisy[/size]
