Author Topic: What kind of brake fluid do you use?  (Read 9365 times)
« on: March 22, 2006, 06:51:22 PM »
please tell us what kind of break fluid u use?
« Reply #1 on: March 22, 2006, 09:26:57 PM »
Joe I recently replaced the fluid in mine cost was around  $40.00 (full evacuation of lines and master cylinder )best $$$ I have spent ,had air in the rears now it stops. stop's well as to what fluid they used  ;30 :evil
« Reply #2 on: March 22, 2006, 09:39:21 PM »
did u do it urself Nick?
i got my mechanic to do it...can b messy
read this link...it is intresting
http://www.advanceautoparts.com/english/youcan/html/ccr/ccr20011001bb.html
Offline Shane Finn
« Reply #3 on: March 22, 2006, 10:36:16 PM »
Try Castrol Super Dot 3 from Repco. It has a boiling point much higher than you might expect for a cheap DOT3 fluid - close to much more expensive DOT4 fluids. Also I recommend getting some Earls speed bleeders to help with the bleeding.
I bleed mine about 12 times a year (whenever I change back and forth from race pads) and replace the fluid completely yearly. I have a Mity-Vac vacuum bleeder but find that the speed bleeders are just as good if you don't want to buy the vacuum bleeder.
2001 Z06, Torch Red
