Author Topic: Another option  (Read 21608 times)
Offline rebel
Another option
« on: December 16, 2002, 09:33:18 PM »
Can anybody give a technical reason as to why my steering shudders from 110kms - 120kms where its smooth as silk below and after .... ?
I know about wheel balance, alignment, and chassis resonance but it doesn't make sense to me that it's only for that 10kms range.
... and don't say it's a speed alert for freeway driving ... :D
Thanx ...
Another option
« Reply #1 on: December 16, 2002, 09:49:51 PM »
did you have a girl in the car at the time!!!,think about it.! (sorry its not a serious answer):luv:flower:bold
Offline rebel
Another option
« Reply #2 on: December 16, 2002, 09:56:40 PM »
should I have used the word rattles instead then ..... ;laugh
Offline Adam
Another option
« Reply #3 on: December 16, 2002, 10:52:07 PM »
It is balance, it's to do with resonance, once it falls into a resonance it will shake, high highs and low lows doubling up on itself.
Its like when armies cross bridges they don't march coz the resonance could destroy it.
It doesnt neccicerly mean tire balance either. Youll find that manufactures have tolerances on wheels, on how eliptical they can be, and youll find they usually alow a lot of eliptaclity (dunno if thats an actual word).
You may find going round a gradual corner between 110-120 also changes the vibration if its in 2 wheels because they to fall in and out of resonance with each other.
Best would be to identfy the inbalance, try to correct it but also to put the worst wheels on the back. If there all bad, a regular (5,000-10,000km) tire rotation should minimise the tires getting worn improperly thus worsening the problem.
I've been there an done that with balancing. My dad fitted oversize wheels to 4wd and the balancing was a nightmare, bought new wheels and they were off too. The bigger the wheel and tire, the more pronouced a bad balance is. There is some vibration at 90-100km/h and we consider ourselves lucky.
Bear in mind that a re balance of your wheels may not solve the problem, it might just shift it to a different speed range, if your unlucky it will be below 110!
Adam
I'm a highway staaaaaarrrr...
Another option
« Reply #4 on: December 17, 2002, 09:28:33 AM »
Geeze, where do you start with this one?  I'm with White Rider on this one.  It's either a tyre imbalance or a part of the tyre could be seperating.
Swap the fronts to the back and see what happens.
Offline rebel
Another option
« Reply #5 on: December 17, 2002, 10:54:16 PM »
Brand new tyres guys!! I'm leaning towards the wheels themselves as they are chrome wires and not the best for big horsepower performance. Even when new and properly tuned to be perfectly round, they look fantastic but 300hp will shake 'em out real quick.
Thanx ...
Another option
« Reply #6 on: December 18, 2002, 09:12:16 AM »
I'd still swap front to rear to isolate which wheel.
Offline Adam
Another option
« Reply #7 on: December 18, 2002, 10:03:08 AM »
Brand new tyres does'nt matter. Brand new tyres are still suseptible to manufacturing faults, in which case you will be able to get replaced if their out of the tolerances.
A trip to a good tyre center should isolate the problem wheel from tyre and which one(s).
Adam
Offline rebel
Another option
« Reply #8 on: December 18, 2002, 10:16:02 PM »
done! Thanx for your posts !!
:D
Another option
« Reply #9 on: December 19, 2002, 12:54:21 AM »
If they turn out to be out of round you could always shave the treads of them and turn them into slicks. Now that should really make your handling interesting at speed.:22
