Author Topic: any1 used them b4?  (Read 25460 times)
any1 used them b4?
« on: March 02, 2006, 08:37:16 PM »
http://www.gmpartsdirect.com
pls let me know whether u have used them
Offline Thunder Kiss
any1 used them b4?
« Reply #1 on: March 02, 2006, 09:11:48 PM »
No, I buy all my auto parts HERE.  They seem to have all the "hard to find" parts.  ;-)
any1 used them b4?
« Reply #2 on: March 02, 2006, 09:13:04 PM »
oh thanks...will check it out:22
any1 used them b4?
« Reply #3 on: March 02, 2006, 09:20:22 PM »
checked it out...not a huge range!
by the way how do u have a link covered under a name....?
any1 used them b4?
« Reply #4 on: March 02, 2006, 09:37:19 PM »
It's standard "bulletin board" code.  There's a lot you can do with it.  Click here to learn more.
any1 used them b4?
« Reply #5 on: March 02, 2006, 09:40:40 PM »
ur legend thunder!!!;41
any1 used them b4?
« Reply #6 on: March 02, 2006, 09:47:02 PM »
Well when your a posting a link you first click on this button  A window will then open asking "What name should be shown."  In this example Thunder used HERE.  You then click OK.  Another window opens and you then type in the URL  [link address]  then click ok again.
When the message comes up on the screen instead of just showing the URL it shows, in this example, HERE.
I usually when provind a link will use the words CLICK ME or CLICK HERE
Hope that helped ya.
POST EDIT:-  Looks like Thunder got in while I was typing.  Quick on the keys there Thunder.;39
any1 used them b4?
« Reply #7 on: March 02, 2006, 09:48:36 PM »
Try (without the spaces):
Code: [Select]
[ url=http://support.invisionfree.com/index.php?act=legends&CODE=bbcode] CLICK HERE [/url ]
any1 used them b4?
« Reply #8 on: March 02, 2006, 09:53:19 PM »
any1 used them b4?
« Reply #9 on: March 02, 2006, 09:57:30 PM »
click here!
It works!
Now try adding color.
eg. [ color=red ] blah blah blah [ /color ]                  (again, no spaces)
any1 used them b4?
« Reply #10 on: March 02, 2006, 09:59:43 PM »
Code: [Select]
yahooooooooo working thanks
any1 used them b4?
« Reply #11 on: March 02, 2006, 09:59:56 PM »
So, you buy any muffler bearings from Kaleco lately TK? ;41
any1 used them b4?
« Reply #12 on: March 02, 2006, 10:47:55 PM »
Don't be silly!
The real performance is in their piston return springs.
Originally posted by Kaleco Auto
 KaleCoAuto has produced the highest quality piston return spring to date! High temperance chromed metal resists temperatures up to 300'f. KaleCoAuto piston return springs FORCE the pistons back into the motor, no longer relying on gravity! This effectively increases your revs, horsepower, and peak torque! You must buy one return spring per piston. Rotary engines require install of pistons for full compatibility. One per piston. Please specify if you are using a boxer motor!
any1 used them b4?
« Reply #13 on: March 02, 2006, 10:57:48 PM »
They have some interesting interior accesories too... ;41
Sorry for the hijack Jolinari.
any1 used them b4?
« Reply #14 on: March 02, 2006, 10:59:04 PM »
thats fine...learning more from others
