Author Topic: C6 Nav Radio Problem  (Read 12689 times)
« on: January 30, 2006, 08:44:59 PM »
For those of you that are lucky enough to be getting a C6.  There has been a problem with radio interference with C6's with NAV radio's.
I found this on another site
"Nav Fix Is Finally Here !!!!!!!!!!!!!!!!!
For all who have been waiting painfully like my self
There is a light at the end of the dam Static mp3 tunnell !!!!!!!!!!!!!!
ASI Resolution - Poor and/or No Radio Reception, Intermittent Static on FM with Navigational Radio System (Update Radio Software) #05-08-44-014A - (Dec 9, 2005)
2005 Chevrolet Corvette (Domestic and Export) with Navigation Radio
This bulletin is being revised to provide correction information. Please discard Corporate Bulletin Number 05-08-44-014 (Section 08 -- Body and Accessories).
Condition
Some customers may comment on the following conditions:
• Static is heard on stations with an otherwise strong signal, after the ignition is turned on.
• The radio is unable to stop at specific stations when using the "seek" function.
Correction
DO NOT REPLACE THE RADIO
Important: The software is updated using a CD, not through SPS programming. New software, P/N 15853651, can be obtained from GMSPO. Dealers should retain the service CD for future use.
The software update will do the following:
• Modify the signal interface with the ARS module to correct the reception condition.
• Add an on-screen message to remind the customer that a destination is required before a route can be planned.
• Add MP3 functionality.
The navigation/radio software, P/N 15853651, should be updated using the following procedure:
Important:
• This software can ONLY be used for updating the 2005 Corvette navigation radio, P/N 15263014. Do not use these CDs to update any other vehicle's navigation radio. The radio part number can be verified via the Tech 2®.
• Software CDs and a Tech 2® are required to complete this procedure.
• Use of latex gloves is recommended to avoid fingerprints on the products and/or discs.
• If the vehicle is turned "off" during updating, the "software updating" process may not work and a new navigation radio will be required.
Follow the steps below to complete the software update.
Turn the ignition "on" with the engine "off" by holding the ignition switch in "ACC" mode for at least 10 seconds.
Open the tilt screen (navigation screen) to gain access to the DVD drive.
Eject the navigation DVD from the DVD drive (bottom slot).
Important: It may be necessary to close the radio screen for Disc 1 - Navigation to begin operation. If the navigation software version in the navigation radio is the same or higher than v.1312, the software updating will not start.
Insert Disc 1- Navigation software version 1312 into the DVD slot.
"Preparing to Load System Software" is displayed on the screen along with a progress bar. It will take approximately 5 minutes for Disc 1 to load.
After Disc 1 - Navigation has completed the navigation system will automatically restart. Eject disc 1 from the DVD slot. Insert Disc 2 - Audio software version 01.0F into the DVD slot.
Important: Approximately 10-15 seconds after inserting the disc, the screen will go blank. It will appear that the radio has shut down and/or locked up. This is the mode the radio will go into when the software is updating. If the audio software version in the navigation radio is the same as v01.0F, the software updating will not start.
When Disc 2 is completed, the system will automatically restart. It will take approximately 5-10 minutes for the system to restart. Remove Disc 2 - Audio from the DVD drive.
Turn the vehicle off. Open and close the driver's door and wait for 60 seconds.
Turn the vehicle on and reinstall the customer's navigation DVD.
Press the "NAV" button on the navigation radio, then press the "Agree" soft key on the screen.
After the map screen is displayed, touch the map screen the confirm that the map can be scrolled.
Using the Tech 2®, clear any/all DTCs from the radio.
Part Information
Part Number
Description
15853651
Disc -- Navigation Data
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
R9707*
CD Update - Radio/Navigation Software
0.5 hr
*This is a unique labor operation number for bulletin use only. It will not be published in the Labor Time Guide"
Well lads there ya have it.  Modern technology at it's best.:grr
Your bloody joking. Do ya have to rub your belly and pat your head at the same time while standing on one foot in the rain during a stampede of wild elephants and one baby zebra? FAAAARRRRKKK me!
Are they sure that it's a car and not an FA-18?
Offline MADVET
« Reply #1 on: January 31, 2006, 09:19:50 AM »
"DO NOT REPLACE THE RADIO"
I think i would.....probably easier.
NOW WE'RE TORQUING!
« Reply #2 on: January 31, 2006, 11:12:30 AM »
what car have u got madvet?
