Author Topic: help on my horn  (Read 13896 times)
help on my horn
« on: January 10, 2006, 09:23:47 PM »
horn does not work...whee do i start? relay? if do where is the relay located?...do u suggest any  auto electical shop specialisin in american vehicles?
help on my horn
« Reply #1 on: January 10, 2006, 09:24:48 PM »
took it today to this guy on buffalo road...he was scratching hios head...he did not know where to start or the job is 2 small for him....so if u recommend some1...pls let me know
Offline MJ427
help on my horn
« Reply #2 on: January 10, 2006, 09:26:35 PM »
any decent auto electrican should be able to fix it
help on my horn
« Reply #3 on: January 10, 2006, 09:27:36 PM »
how long does it take to do it u rekon?
help on my horn
« Reply #4 on: January 10, 2006, 09:33:06 PM »
Joe... i think you need to place this thread in the pre 84 forum.
I recommend that you firstly start with taking the horn off, or testing it on the car like advised... that way you can figure out if the horn is okay or not... then work backwoods.
The horn may only need some adjusting, i recall on an old car i had in my younger days that they needed oiling...im not sure now..
Then if you know the horn is okay, then work on the wiring system.
I have the wiring diagram for my 69 Vette, i can copy it at work and give you a copy... it should be the same..
OK...;27
help on my horn
« Reply #5 on: January 10, 2006, 09:35:02 PM »
yes do that please....
OK...;27
help on my horn
« Reply #6 on: January 10, 2006, 09:50:57 PM »
OK...;27
Assuming you have checked for the obvious stuff like a blown fuse I would say Michael is on the money in my opinion.
Get a schematic if you can and follow the wiring and see if you have current at different points to pinpoint where the problem is.  Check to make sure the horn button has a good contact and then see if you have power at the horn and work your way back from there.
You should be able to do this with a test light and then go from there.
I'm sure a few of the other guys here will chime in.
help on my horn
« Reply #7 on: January 10, 2006, 09:54:54 PM »
thanks VO
Offline cosmicvette
help on my horn
« Reply #8 on: January 10, 2006, 10:02:20 PM »
yep, great advice VO and mike.
(Thread moved to Pre 1984)
help on my horn
« Reply #9 on: January 10, 2006, 10:12:26 PM »
thanks alex
help on my horn
« Reply #10 on: January 10, 2006, 10:33:12 PM »
Anyway... i will make you a copy tommorow (Weds) and give it to you on friday if the runs on... otherwise, if you happen to be in the area... (ashfield) pop into my work.
M;36
help on my horn
« Reply #11 on: January 10, 2006, 10:54:34 PM »
M;36
good stuff
