Author Topic: www.energysusp.com.au  (Read 8515 times)
Offline The White Knight
    • www.amcca.com.au
« on: April 10, 2005, 03:43:15 PM »
;33 I was talking to Dave Clee last night from Pontie world at the rock & roll night & he is bringing suspension gear in from the USA at a good price I know he will add to this sight with more details.
 :D  Garry
« Reply #1 on: April 10, 2005, 07:16:22 PM »
Good news.  The rear end is next on the project once the beast has been running for a couple of months.
Offline ozpont
« Reply #2 on: April 10, 2005, 10:06:34 PM »
...what we were talking about is to be found NOW on http://www.energysusp.com.au
... For those who are aware of the USA's best polyurethane providers and their science behind the formula's.. ENERGY SUSPENSION probably needs no into.
... For those that don't   know Energy Suspension USA   provides a higher performance grade of replacement bushes & body mounts for our sorts of USA cars..  thru a  variable series of grades of Polyurethane for purpose use for muscle car, drags racing needs, truck and military use. Not all poly is the same.
     Energy Suspension bushes and mounts are also alot more resiliant to chemical or oil damage like rubber is.
.. Energy is the top USA seller and for good reason but it can be or has been both harder to get  all the various parts available then normal suspension rubber bushes & mounts.
..  Over the last 6 months we've successfully introduced Energy Suspension direct from USA Factory thru to Australia. Its the only Factory direct access in  Oz.. .. not to say others can't bring it in from other  USA resellers etc.. . but let the pricing YOU GET BE THE JUDGE...  The Corvette rang runs mid 50's to late 90's.
... no big deal... ok...
but for a change a few good apples are falling over your side of the fence again...... its  now simply supplied to you at the USA cost.. converted to Australian or NZ dollars as  it has to be..    thats it..   Energy's USA parts at the Energy Listed price.
.. If you want to order or have a look over some of the parts NOW available .. and the costings etc... we have again structured an open secured web site.... in Australianm - open NOW.. and about another 100 items to come over the next month or so as the stock arrives.  We're not here to rip ANYBODY off.. .never have been... but you be the judge.
ALL STOCK LISTED IS IN STOCK.. delivery around Australia is $14.20.
Have a look.... you can have a ' 66 body mount kit for $66 ... Australian.. or a 80 model full master kit for A$352... thats with all this sort of stuff...
Rear control arm bushings
Rear spring cushions
Front end link set
Front control arm bushings
Power steering ram bushings
Transmission mount
Differential carrier bushings
Rear strut rod bushings
Rear sway bar and end link bushings
Ball joint & tie rod end boots
     I am not trying to be a salesman... just making things happen that maybe will help some of you.
    Orders are web based only.. go to www.energysusp.com.au.
Thank you ,
Dave
« Reply #3 on: April 10, 2005, 10:30:49 PM »
Nice site.  All my front, gearbox, body and engine mounts are done, but I will be interested in anything for the rear end suspension on a 77 when available.  I'll keep a watch as you get more goodies in.
