Technical Tips
Electrical-Electronics-Air-Lighting-Guages-Security-Vacuum
digital cluster
Topic: digital cluster (Read 10471 times)
onya
Four Barrel
digital cluster
January 26, 2005, 07:30:28 PM »
One of the blinker globes is not working in the instrument cluster, to change the globe do I need to remove the cluster to get access to the globes.;30;30;30;30:20:20:20
Thunder Kiss
Four Barrel
digital cluster
January 26, 2005, 09:49:38 PM »
Here
you go. You don't have to remove the cluster, just the outer dash panel.
86er
Four Barrel
digital cluster
January 27, 2005, 12:03:57 PM »
I have a GM work shop manual if you need to cast your eyes over, I haven't had the dash out of mine but it doesn't seen too bad (toungue in cheek)
Vette blues
onya
Four Barrel
digital cluster
Reply #3 on:
January 28, 2005, 04:41:36 AM »
Fixed, thanks just a loose globe. When conversion was done, they had some strange ideas on how to how dash panel in. Easy job. I don't think so.
77CVT
Fuel Injected
digital cluster
Reply #4 on:
February 01, 2005, 05:43:17 PM »
Using a small vacuum tube to get the globes out makes it easier too!
Technical Tips
digital cluster
