Author Topic: Lowering my C4  (Read 18774 times)
Offline corman
Lowering my C4
« on: November 17, 2004, 08:08:22 PM »
Hi there, just wanted to get some feedback from you guys out there regarding lowering a C4. I see in my catalogue that I can buy the bits for around $40, give or take. I have no idea where they go yet, or how much work there is involved in putting these parts in. So before I buy them could anyone shine some light on this procedure?
Offline Thunder Kiss
Lowering my C4
« Reply #1 on: November 17, 2004, 10:04:14 PM »
I wouldn't go too low or you'll have bottoming out / scraping problems.  The front of my car sat low enough for me, but I did buy longer bolts (from the local fastener shop) to lower the rear of my car a little.  The golden rule is don't go too low, these cars don't have a great deal of clearance to begin with.
Offline corman
Lowering my C4
« Reply #2 on: November 18, 2004, 06:06:17 AM »
Hi Thunder Kiss, I know theres not much room under there, but maybe I would just like to even it up a bit, like you did with the back. I can gauge the height pretty well by the Mcdonalds speed humps. If I get only ONE quarter  pounder value meal then I can make it over the speed humps OK. But if I get the sundae with it, it touches slightly !!!!!!
Lowering my C4
« Reply #3 on: November 18, 2004, 11:19:04 AM »
The rear is a piece of cake - just buy some longer grade 8 bolts from your local bolt shop.  For the front you will have to do a bit more work undoing the front suspension and putting in  the wedges.  Wedges will probably only lower it 1/2 inch at the most, but is on my "to do" list.
Offline corman
Lowering my C4
« Reply #4 on: November 18, 2004, 06:54:32 PM »
OK, thanks 77CVT. I've ordered the bolts from Ecklers, I know, I know, I could have saved heaps buying them at a hardware store, but I ordered some other stuff as well so I just had it all included. If they dont come with instalation instructions I'll be asking you where they go, cause I've looked at my manual and I'm razzed what I should do with them.
Lowering my C4
« Reply #5 on: November 18, 2004, 08:00:11 PM »
You'll find the rear will be dead easy, here is a (poorly focused) photo highlighting the bolt.
Looks like I need new spring cushions;mmm
Offline corman
Lowering my C4
« Reply #6 on: November 18, 2004, 08:09:06 PM »
OK, thats great Thunder Kiss . I'm grateful, when the bits arrive I'll get them in, hopefully before I come down in December.
Lowering my C4
« Reply #7 on: November 19, 2004, 12:11:57 PM »
For the rear, support the rear on jackstands.  Then jack up the spring making sure you use a c clamp (on the inner side) to stop the jack from moving and sending you to hospital.  Use a thin block of wood to stop the clamp from marking the spring.
Jack each side one at a time.  When the spring bolt becomes loose (spray som WD40 on the threads) undo the nut and remove the bolt taking note of where each spring pad was.
Put in the new bolt and spring pads, tighten up the nut and gently lower the spring.  When both sides are done you can remove the jackstands.  You can tighten/adjust with full pressure on the nut.  Hint:  It will be easier to do the nut up a fair way and loosen it to the height you want with the spring fully down.
The lower the nut on the bolt the lower the car.  To raise it tighten the nut up.
For the front - follow the Haynes manual to undo the lower control arms etc.  There are rubber/aluminium strips on top of the spring in the centre.  Replace these with the lowering wedges.  (Good luck with the ball joints!!!!)
Note: If you want to remove the spring, if you have a stock spring (non Z51) you will need to jack the car up at least 50-60cm !!!!
Remember - spray everything with WD40 or the like, make sure the beer is already cold and ensure little kiddies are out of earshot.  Have fun!
Lowering my C4
« Reply #8 on: November 19, 2004, 05:39:10 PM »
Good post 77CVT
Great step by step procedure there 77CVT, here is my two cents in addition to what you posted for the front:
Some cars may have more than one aluminium shim - remove them all and then you have to remove/cut off the rubber cushion that is bonded to either side of the top section of the spring.  Be forewarned that cutting the rubber bushing off the top of the spring is the most tedious part of the job - I hated doing it (be careful not to gouge the fibreglass spring or remove a finger while doing it).  If you measure the height of the rubber ontop of the spring (the bit you cut off) + the shim(s) above it combined, subtract the height of the replacement plastic shim to determine how much to trim the top edges of your spring retainer down.  You may want to keep the aluminium shims from atop the spring for use under the spring retainer* if you run out of thread on the retainer bolts (you probably will).
I measured the height at the chassis on each corner of my car before lowering (so as to keep track of changes and maintain the factory "rake" from front to rear.  Lowering just the rear may cause issues at high speed (more air under the front).  I can't verify this firsthand but don't want to find out either...
*If your car is a pre-87 car you may need to buy the updated aluminium spring retainers for the front spring (which you will have to trim down after lowering the car).  If you don't trim them your spring won't be securely mounted.
Offline corman
Lowering my C4
« Reply #9 on: November 19, 2004, 08:25:08 PM »
Thanks guys I grateful for your input. I not sure that lowering is worth the trouble yet, and I can see your point Vette Obsessed with just lowering the arse. I was a bit concerned with tyre clearance also on the back, I might wait and see the other Vettes in the club to find out how mine compares in height.
Offline Tom Matic
Lowering my C4
« Reply #10 on: December 12, 2004, 09:55:18 PM »
Has anyone tried using Coil-over shockies (adjsutable ride height) and dispensing with the leaf springs altogether?
The other possible option is air bags.  The big advantage here is that you can adjust ride height very quickly, but I think that there is a problem with insufficient clearances at the front Chassis mounting point which would require special fabrication of a new upper mounting point.
Lowering my C4
« Reply #11 on: December 13, 2004, 10:38:39 AM »
I would do coil overs in a heartbeat - if it didn't cost over $2500.  :b4
Offline 86er
Lowering my C4
« Reply #12 on: December 13, 2004, 12:32:16 PM »
Coil overs are the way to go, I have been in a C4 that had them fitted & the ride was very good.  This option is a far better one than the air bag set up
Vette blues
