Author Topic: Rear Suspension noise  (Read 22262 times)
Offline Philip
  • Car: 76C3
« on: September 27, 2022, 02:42:07 PM »
Hi again.
Just recently got my 76 blue slipped and road registered. Went for a maiden road journey for about 2Hrs, all went fine except for the rear suspension creaking and squeaking at low speed over speed humps and bumps in the road. Wondered if someone could possibly point me to a likely culprit or a common cause. I replaced the spring hangers a little while back so I don't think it will be that. I suspect that all the rubbers on the rear end are very old. Thanks
Re: Rear Suspension noise
« Reply #1 on: September 27, 2022, 09:46:44 PM »
Rubbers dry or stuffed uni joint look for rust around bearing cap rubbers
Offline Philip
  • Car: 76C3
« Reply #2 on: September 28, 2022, 09:17:24 AM »
Thanks Geoff
Uni joints look fine. Certainly sounds like dry rubbers to me, I might start at the struts and work my way through and hope that it's not the trailing arm bushes. Cheers.
« Reply #3 on: October 12, 2022, 07:40:29 PM »
I  did my uni's on the 78 they looked ok when replaced was totally different. Not real expensive to do, same with strut rods, spring liners also. Are you doing work yourself or paying someone?
Offline Philip
  • Car: 76C3
« Reply #4 on: October 13, 2022, 02:25:00 PM »
Doing work myself, haven't had to have work done by others as yet. I have purchased a new set of strut rod bushes but haven't fitted them yet. Strut rods are the adjustable ones, I'm not sure if they are original or not because I don't know if the 76 came with those or the cam type. I haven't had a look at the spring liners though. It will probably be a process of elimination. Thanks again.
« Reply #5 on: October 13, 2022, 05:41:52 PM »
Jack the car up under chassis in front of wheels you will soon work out what is worn. Check side yoke of diff if it has pulled out of diff. Grab wheel top and bottom and try rocking repeat at 3 & 9 o clock. 3& 9 is wheel bearing, 12 & 6 is side yoke. To turn wheel you will have to raise  hub as uni's bind up when wheels hanging
Offline Philip
  • Car: 76C3
« Reply #6 on: October 14, 2022, 08:50:58 AM »
Thanks,I'll do the checks.
