Author Topic: Tyre size for c3  (Read 38123 times)
Offline Philip
  • Car: 76C3
Tyre size for c3
« on: December 07, 2021, 11:41:17 AM »
Hi guys
I have a76 vette recently purchased and have 265 x 50 x 15 tyres on what I think are standard rims I recently replaced handbrake cable to rear brakes. I now have the tyres rubbing on the brake cable.I have to replace all tyres due to the age and condition of these. Can you give me a decent tyre size to get that will fit without rubbing as I'm not an expert on tyres and don't want to purchase something that will give me a problem. Thanks
Re: Tyre size for c3
« Reply #1 on: December 07, 2021, 02:11:59 PM »
Hi Philip. The Standard size for a C3 is 235x60x15 Front and 255x60x15 Rear. Some people shoe horn 255x60x15 on the Front  . Hope this helps .Ray
Offline Philip
  • Car: 76C3
« Reply #2 on: December 07, 2021, 02:57:18 PM »
Thanks Ray
Wasn't sure whether the 255's were still too big but I'll give them a go, if they still rub the brake cable I'll do something to prevent that. Cheers
« Reply #3 on: December 07, 2021, 08:18:49 PM »
255 60 15 should be fine on the rear are the wheels alloys or rally wheels ? Handbrake cable bracket can be relocated to top of trailing arm. The metal bracket is available as a replacement part. I personally like 245 60 15 as can run a lot of castor on front without rubbing in back of guards. 245 60 15 tyres are available from tempe tyres for $161 fitted and are nice and quiet on highway at speed have had them on car for a year now with no complaint
Offline Philip
  • Car: 76C3
« Reply #4 on: December 08, 2021, 11:14:06 AM »
Thankyou Sirfixalot :laugh:
What brand of tyre do you run, my current ones are Goodrich TA. on Rally wheels, I'll keep the cable bracket in mind. I will get some prices up here in Newcastle. I'm sure I will be pestering you guys quite a lot in the coming months. The car being RHD certainly presents a lot of challenges from dash to hood locks. Just a note to let you know that from my last post regarding bumper covers I managed to track down Simon Taylor in Qld and he is currently making the covers for me at a reasonable price, thanks again.
« Reply #5 on: December 09, 2021, 07:51:02 AM »
Galaxy Radial Gt they have a higher speed rating than BF Goodrich and also a higher load rating. RHD questions can usually answer have converted a couple of cars so have come across most problems
Offline Philip
  • Car: 76C3
« Reply #6 on: December 09, 2021, 09:26:31 AM »
Thanks again. That's good news concerning RHD problems. I still have many questions and will be in touch as I go along on this journey. Cheers
Offline JackRussel
  • Car: Toyota Landcruiser
« Reply #7 on: January 05, 2022, 08:31:00 PM »
I read here: https://www.corvetteforum.com/forums/c3-tech-performance/675398-tires-bp
People use different tires: 245/60/15, 255/60/15, 235/60/15, and even exotic options like 295/50/15
I'm not giving advice, I'm just sharing information about options and problems with them. It might be helpful to someone.
Offline Philip
  • Car: 76C3
« Reply #8 on: January 06, 2022, 09:27:01 AM »
I'll choose a size after some further discussion, Cheers
Offline stingray
« Reply #9 on: January 06, 2022, 10:46:00 AM »
I run 255/60/ 15 BF Goodrich TA/ Radials on standard corvette wheels, when I bought the car 20  years ago they had 225 too skinny
Offline Philip
  • Car: 76C3
« Reply #10 on: January 06, 2022, 04:51:30 PM »
Hi Stingray
Thanks for your input as well, I'm leaning towards 255 on rear and maybe 245 on the front at this stage.
« Reply #11 on: January 10, 2022, 06:33:14 PM »
73 thru 77 are basically steel Rally wheels fitted with GR70-15 tyres.
However in 73 a cast alloy wheel was available but was " hecco en mexio" - and because of flaws was discontinued.
The tyre coding changed and your car would from factory most likey have steel rally wheels now fitted with P255/70-15 Goodyears.
I believe you could option for 60% profile tyres, and white lines &/or lettering.
From 78 onward Rally wheels were std, but the Alloys returned after the casting flaws were fixed, and were options 78 ~ 82.
My 78 has 15" Rallies and 255's all round, but is a stock setup. Ergo there are no issues with 60 or 70% profile tyres, they clear, drive and handle as good as any 78 car can do.
That's actually a lie, the 78 has 255' rear and 225 (ex "Stingray's) on the front, don't ask its a long story, but that combination makes the car look like its ducking down in the front to get under the limbo stick.
I know a person, who has a set of Rallies with 255's fitted !?. In fact there may be a set of S/S trim rings & caps. The tyres are Waaay tooo old and RS, but for static display, they'd fill the bill.
Offline Philip
  • Car: 76C3
« Reply #12 on: January 10, 2022, 09:04:51 PM »
Yep thanks for the info. I think I will keep the rally rims instead of alloys and I was going to get my rims sandblasted and painted but I have not gotten a price for that yet. Maybe if its too expensive I may just see about another set of rims. Probably stick with the 255s x 60. Thanks
« Reply #13 on: January 11, 2022, 07:50:38 AM »
Maybe get a price from a powder coating company, they sand blast then powder coat great finish. I have always found them reasonably priced . Ray
Offline Philip
  • Car: 76C3
« Reply #14 on: January 11, 2022, 12:26:08 PM »
Thanks Ray, I'll check it out
« Reply #15 on: January 12, 2022, 08:13:53 AM »
I think you will be pleasantly surprised cost to sandblast and powder coat all you need to do is find a company doing a run on silver. I have had trailing arms done with all the brackets,hub etc in black for $90 a side
Offline Philip
  • Car: 76C3
« Reply #16 on: January 13, 2022, 09:33:17 AM »
Thanks sounds good.
« Reply #17 on: January 19, 2022, 07:36:04 PM »
With the rubber off the rims, a good scrub, light sand if required, etch/primer and a spray tin of Wheel Silver and once the trim rings and caps go on - they look great.
Offline Philip
  • Car: 76C3
« Reply #18 on: January 20, 2022, 06:31:54 AM »
Thanks for that. My rims were painted red with 2 pack paint and are chipped pretty bad.
