Author Topic: C4 87 Right Hand Diff side yolk  (Read 13661 times)
« on: July 21, 2021, 10:17:44 PM »
After a r/hand yolk that goes into diff Dana 36. I believe L & R are different lengths. If anyone can confirm?
Re: C4 87 Right Hand Diff side yolk
« Reply #1 on: July 23, 2021, 01:33:55 PM »
In 87  GMSM on page 4B-2 Rear Axle the picture shows part 33 designation on the LH & RH  Yoke Axle Shafts
I would assume since both LH & RH are numbered the same, then ergo they are interchangeable.
But I'm not the best when assuming stuff.
HOWEVER, after sitting on this section I can see on 4B-11 a note about the lengths as 7.875" and 8.5" .
Model 36 and Model 44 respectively and they should have a metal tag c/w numbers.
I hope the above helps, diffs are not in my vocabulary .
« Reply #2 on: July 23, 2021, 09:14:13 PM »
So Doug you are saying Dana 36 are 7.875" and Dana 44 are 8.5". I saw on one of the parts suppliers L & R axles had a different part no
