Author Topic: Exhaust Popping?  (Read 55573 times)
Offline Matt G
  • Car: 1970 Coupe 350 manual.
Exhaust Popping?
« on: March 08, 2020, 07:13:48 PM »
Hi guys, just curious to understand a phenomenon that happened recently. My ‘70 was a little harder to start than normal (it had been a while between starts...) and when I did get some life, it settled down to an pretty normal idle, however it was popping (almost more like a backfire) out of my right side exhaust pipe. Frequency was probably every second or two. I parked it back in the garage for a later check/review.
Today I pulled all the plugs and the right side (cyl 2/4/6/8) were pretty even, but all were wet/oily. The left side (cyl 1/3/5/7) were a little carboned up ( similar to the right) but mostly dry.  I gave them all a good clean and loaded them back in. I figured that it was running too rich, so I checked my mixture screws: FL @ 1-1/8 turn from seat), FR @ 1-1/8, RL @ 1-1/2, RR @1-1/8. I screwed in the RL in to 1-1/8 turn, figuring that it may have worked it way out a little, but didn’t expect it to change the heavier fuel load on my Right hand side.  I check all of my spark leads and they looked perfect.
Started up okay, however again a little harder than usual. When started, no exhaust pops/backfires were noticed.
Any ideas?
Re: Exhaust Popping?
« Reply #1 on: March 10, 2020, 11:31:28 AM »
Sticking valve?
« Reply #2 on: March 10, 2020, 04:29:06 PM »
 Two saying come to mind when it comes to  motor vehicles
If it ain't broke, don't fix it
 Guessing is cheap. Guessing wrong is expensive.
Offline Matt G
« Reply #3 on: March 10, 2020, 11:54:28 PM »
I think an intermittent valve seat might be close to the problem (after deep thought an many beers). The bit that has me confused it why most of my right side cylinder bank had similar spark plug characteristics.  If it was one valve (logically my exhaust valve in this case) then wouldn’t only one cylinder show different characteristics?  It’s highly unlikely that it’s all four cylinder 2/4/6/8.
I overheated my ignition box (MSD 6A) back when we had the 46deg day, and she stopped until the flat bed delivered her home (and cash was exchanged 🤬), but  I can’t imagine how it would create a cylinder or bank specific issue with firing.
Assuming it’s a valve seat or sticky stem seal, is there an easy way to test? I have a braced roller rocker train, but I could test clearances if valve/rocker adjustment is the key problem.  I can’t get a cylinder pressure tested in behind my extractors to test variable pressure. Can I buy a screw-in pressure tester? Even better if anyone knows of an electronic logging version...!!!
Any suggestions on how to test for valve stickiness?
If you pm me I can send a video, pics, etc.
« Reply #4 on: March 12, 2020, 08:49:56 AM »
Check exhaust runner temps with an IR temp gun?  Might narrow it down to which cylinder is playing up.
« Reply #5 on: March 12, 2020, 11:11:19 AM »
yes,
you could try this
 with engine cold , you can use the finger pyrometer test . as exhaust starts to warms up.
DONT BURN YOURSELF if you use this method.  only viable for the first 10 to 15 seconds of engine running.
« Reply #6 on: March 12, 2020, 05:25:37 PM »
My 1970 454 with solid lifters and stud girdles had a similar problem until I got the valve lash adjusted back to the cam spec. That fixed it.
Offline Matt G
« Reply #7 on: May 17, 2020, 12:29:05 PM »
Thanks guys, I took her for a good run  sitting on about 3k for a while, and all nice again (plug colours, idle, etc). Obviously a good clean out (not a fanging cleanout close to home) is what was needed. However the valve comment has started a ‘COVID QUEST’ for me and I’m trying to figure out my Cam profile.
I’ve measured my rocker lift (pushrod side) for every 15deg of engine rotation and have a pretty profile graph, but still no idea of my cam model/tech profile. So now I’m all in. Belts, pulleys and water pump are off, and I’m heading for the front end of the camshaft to see if it has the number marked there (I’m told that it’s either at the front, back or middle).
However I’ve hit a snag and would love to leverage some experience. My harmonic balancer is on tight. I mean real tight. I purchased a puller (3 bolt version) and it ‘ain’t budging. I’ve drenched in WD40 and left it for days with the centre bold under tension, but still no movement. I thought about tapping with a hammer yesterday, but I didn’t think that it would be okay for the journal bearings.
Any loosening suggestions?
« Reply #8 on: May 17, 2020, 05:26:10 PM »
Matt
Did you remove the bolt and washer that holds the balancer on.
Ps apologies for asking , but I’ve seen that mistake a few times. Also the bolt removed and the washer left in place.
Offline Matt G
« Reply #9 on: May 17, 2020, 08:19:24 PM »
Haha, all good for asking BFit. Bolt and washer are out, buffed clean, cold gal coated ready to go back in. I needed to get this out to pull off my p/steer and alt pulley.  It was tight as well, but saw a good tip on YouTube to jog-crank the engine with a breaker bar, and it came off easy.
I’ve seen mixed messages on USA forums to pull the balancer. Hit the balancer, hit the centre pulley bolt, and heat it up, but I think all of them run risk to my main bearings, so I wanted to check with my local gurus 😁👍
« Reply #10 on: May 17, 2020, 09:56:12 PM »
Matt
 NO  hammers and no heat it will just wreck something.
 Matt my number is on the forum .
Committee contacts
Ring my tomorrow .
Offline Matt G
« Reply #11 on: May 24, 2020, 11:10:58 PM »
Thanks BFit. All of your tips were enormously helpful. Thanks again! For the forum, balancer is off via creating a semi-fake bearing against the end of my crank with a series of greased washers. Worked a treat to reduce friction and ensure that I didn’t damage my crank threads with the nose of my puller.
Last question (me being a tight-ass)...  any cheats for rotating my engine when the balancer is removed. The correct tool is a crankshaft socket, but I don’t build engines regularly, so buying one is just one more (single use) tools that I probably don’t really need to buy. Any easy cheat suggestions? Modified ring spanner, simple insert to something else, or a tip for a location on a HD Plastic option?
« Reply #12 on: May 25, 2020, 07:14:21 AM »
Just put the snout bolt back in and tighten it until it turns the engine.
As long as you are smooth, you can then remove it with a quick snap the other way.
« Reply #13 on: May 25, 2020, 08:03:58 AM »
Buy one of these PR66901, you will find one on eBay for $50,   No short cuts here ,  if the alternative methods go wrong it can get very  expensive!
Offline Matt G
« Reply #14 on: May 31, 2020, 09:16:15 PM »
Hi Guys,
Update on my COVID-Quest.  Thanks to some really handy tips from you guys, I have my camshaft grind number.  Ive searched the Crane Cams Master Catalog (USA version), however still don’t know what I’ve got.  The numbers are hand ground (not stamped) and read:
11-28-93 at the top,
“CRANE” in the lower middle, and
TR-250-400-2-6
I’ve sent a note to one of the Crane Cams Tech guys in the USA, however if someone on the forum has a good cheat sheet to decipher, that would be awesome - the suspense of this exercise is like that pre-burnout feeling 😂
« Reply #15 on: May 31, 2020, 10:29:37 PM »
11 - 28 - 93  looks like a us date format
The other number , ?
TR  Trace roller series
250/400  the grind  series
2 duration at 0.200’’ lift
6   GROSS VALVE LIFT WITH ZERO LASH AT THEORETICAL ROCKER RATIO  AT 0.600’’
