Author Topic: Know anyone who can re-program a stock '86 ECU?  (Read 16280 times)
Offline peterw
  • Car: 1986 C4 Coupe Red
« on: November 07, 2019, 09:02:24 PM »
I want to install a disable switch for the overdrive on the 4+3 Doug Nash in my '86.  Car is all factory stock and OD works as it was intended.
I would like to have a switch that disables all the silly factory functions and just be able to engage it when on the highway.
The guys on the US forum say that you can re-program the ECU to stop the factory silliness.
Does anyone know someone in Australia that could do this?
Peter
Re: Know anyone who can re-program a stock '86 ECU?
« Reply #1 on: November 07, 2019, 10:06:13 PM »
Hi Peter this maybe what your looking for , check out Ecklers Corvette Cags Skip Plug Seal Part number 22712  $13 . Ray
Offline peterw
« Reply #2 on: November 07, 2019, 10:48:47 PM »
Unfortunately that part number is for 89-95 with 6 speed.  It has been badly labelled by Ecklers.
I couldn't find one for the 4+3
I have no idea what CAGS is?
Would be nice if someone did a ready made fix for this.
Peter
« Reply #3 on: November 08, 2019, 08:18:17 AM »
Computer Aided Gear Selection
Offline peterw
« Reply #4 on: November 08, 2019, 10:39:47 AM »
I guess that it the light on the dash that tells me when I need to change gear?
Does anyone use that?
« Reply #5 on: November 08, 2019, 03:38:51 PM »
when you find someone, I received a call from a vette owner in SA looking for some help with the ECM in a 2005 C6.
« Reply #6 on: November 09, 2019, 03:14:33 AM »
Give Steve Rosenfels a call. He does ECU reprogramming on a range of engines for tuning purposes and he may be able to assist with yours.
https://www.srperformance.com.au/
Offline Ausrs
« Reply #7 on: November 09, 2019, 05:19:21 PM »
Many years ago I had a new prom made for me in the USA ,I found the guy on Thirdgen.org, when I last heard from him this brianlvs@yahoo.com was his email address,from memory it was $100 $us plus postage...My car is an 87 ..I had the later model tune installed,vats delete egr delete fans come on at a lower speed and auto reprogrammed to drop into od at 40 mph .
