Author Topic: C3 seat frame with seat belt holes  (Read 37096 times)
Offline Ollie68
Re: C3 seat frame with seat belt holes
« Reply #20 on: October 09, 2018, 09:57:51 PM »
Im gunna ring him tomorrow arvo and have a chat.
Offline RHD.68.l89
    • www.invisiblecarbras.com.au
« Reply #21 on: October 09, 2018, 11:36:31 PM »
Ollie, the seats I have have the holes through from the back but the trim is not cut out on the front. you can poke your finger through to the front. Located in Melb eastern suburbs. Let me know if you are interested
« Reply #22 on: October 10, 2018, 10:52:53 AM »
Here is an option you can use. works for me. orientation  dint work to well but you will get the idea.
« Reply #23 on: October 12, 2018, 12:40:00 PM »
Bob that is a similar setup to what I supply for 78-82 cars most people aren't comfortable with having to cut slots &  drill holes in trim panels, you only get one go cutting that slot for belt to come out of so webbing doesn't rub. Most people want a bolt in set up with no modification is the first question that is asked
« Reply #24 on: October 12, 2018, 12:53:01 PM »
agree with that .
« Reply #25 on: October 12, 2018, 03:35:11 PM »
My 78 has the original basic seats, the seat belt is a retractable lapsash type, one end anchored at base of B pillar, with the inertia real located in top of B pillar covered by a plastic shroud. The third point is to the floor, on the side of transmission hump.  Base seat layout.
« Reply #26 on: October 12, 2018, 03:49:52 PM »
I dont believe I got that pic to upload, this is the layout for the Anniversary model seat which was then std for 79 thru 82.
« Reply #27 on: October 12, 2018, 03:57:05 PM »
I dont know if this is at all helpfull, but I'm on a roll with uploading pics, so this pic may also help.
