Technical Tips
Engines - Carbies - Exhausts - Dissys
ENGINE REMOVAL
Topic: ENGINE REMOVAL (Read 23650 times)
reserved
Four Barrel
ENGINE REMOVAL
January 29, 2018, 02:06:00 PM »
Does anyone have an engine lifting bracket that bolts onto the inlet manifold, that I could borrow. I know they are only $50, but I would prefer to spend the $50 on parts as this is probably the one and only time in my life that I will remove an engine. An engine stand would also be helpful but not essential. If anyone can help, thanks.
sirfixalot
Fuel Injected
Re: ENGINE REMOVAL
January 30, 2018, 07:32:54 AM »
You are better with an adjustable lifting bar so that you can tilt engine & gearbox as it comes out where are you located?
reserved
Four Barrel
Re: ENGINE REMOVAL
January 30, 2018, 11:53:47 AM »
I am located in the Penrith area. I will be at the Nelson Bay weekend and at the next club meeting. As the car is automatic the gearbox will not be removed.
Don't talk of dust and roses
Global Moderator
Two one thousands
Mood: Honey reinforced
Car: Yes
Re: ENGINE REMOVAL
Reply #3 on:
January 30, 2018, 02:46:06 PM »
i would think hard about getting the trans serviced while you have the engine out, unless you have info,to,say it’s been recently done.
It’s a pain to but the engine back in and find you have a leak.
77CVT
Fuel Injected
Re: ENGINE REMOVAL
Reply #4 on:
January 30, 2018, 03:33:03 PM »
....and while it's out clean some bits, change the drive shaft uni's, etc, etc ..................and before you know it ............. it becomes a 3 month project!
Global Moderator
Two one thousands
Car: Yes
Re: ENGINE REMOVAL
Reply #5 on:
January 30, 2018, 04:30:22 PM »
There is some truth in that last bit.
I had a oil leak at the torque/conv four year on still not finished .
I started an ls1 swap
reserved
Four Barrel
Re: ENGINE REMOVAL
Reply #6 on:
January 30, 2018, 04:54:41 PM »
I had the gearbox reconditioned about 6years ago, but I have never been able to get the motor running smoothly, so I am biting the bullet and pulling the motor to inspect the guts of it. I am hoping to find some small problem such as a worn cam or dickey cam followers. I just want to get the bloody thing n the road.
Global Moderator
Two one thousands
Car: Yes
Re: ENGINE REMOVAL
Reply #7 on:
January 30, 2018, 09:11:18 PM »
It is easy to strip the engine in the frame,
The sump and front can be removed in frame.
If you find something minor it can be repaired.
Just a thought
reserved
Four Barrel
Re: ENGINE REMOVAL
Reply #8 on:
February 01, 2018, 12:23:57 AM »
I need to take the engine out so as I can get someone with expertise to inspect each and every part. Unless there is a crack or a score mark I would be lost, I would not know a worn cam lobe or a stuffed hydraulic lifter if I fell over them. I am still having arguments with myself over the positioning of the oil pump strainer. Oil pressure is a problem but there may be other problems.
77CVT
Fuel Injected
Re: ENGINE REMOVAL
Reply #9 on:
February 01, 2018, 09:16:19 AM »
If the block is ok I'd get it hot tanked and cleaned up (will need new cam bearings). My engine temps dropped remarkably when I did mine.
Oh......and make sure they use some thread sealant on the oil gallery screws at the back of the block. Mine ended up with a tiny, tiny leak which you can't fix with it in the car.
Technical Tips
ENGINE REMOVAL
