Author Topic: All American Mystery Cruise Nights; Camaro Firebird Club; Sept 2017 - May 2018  (Read 31948 times)
Offline StephenSLR
On tonight.
s
Offline Hallsy
  • I miss the old days.
  • Mood: Always happy.
Damn.
Way out west again and too much nerve damage to drive. :tears:
I know that you believe you understand what you think I said.
But I am not sure you realise that what you heard is not what I meant.😱
Offline StephenSLR
Damn.
Got in my car, kicked it over; flat battery!
 :tears:
s
 :tears:
s
You need:
http://batteryfighter.com.au/shop/product/13287/BFA012.html
Keeps my battery in great shape.
Offline StephenSLR
You need:
I live in units and will have to get a power point in the garage one day.
I blame the clock in the Rally Pac. When I switched it on it still had some power as the radio switched on.
It's been probably 5-6 weeks since I drove it so I was quite eager to take her out.
s
Clock and radio memory are two battery eaters on the early models.
Another option is a battery isolator switch, but that means having to reset clock and radio.
Offline StephenSLR
Yeah, I've thought a few times to disconnect the battery but dismiss it thinking I'll take my car out enough, I've gone a month between drives a few times with no problems.
s
C4's onward draw juice 24/7, but decent battery, clean connections (use very small dash of lanolin spray) and battery should last 6-8 weeks without issues.
Your radio and clock would only draw milliamps, most batteries have say 100 amp-hour, so drawing say 50/1000Amps or 50milliAmp it will take a long time to use up the battery. If you get some clear light a charger working off a solar cell may put enough back in to see it right for 6 months.
Of course there is no substitute for start & run up to temp at least every two weeks, better still come on a club run.
Offline StephenSLR
It usually does but that's after weekly driving, I've been a bit lazy over the winter and not driving so much so probably didn't fully charge the last time I took it out.
s
Put a red top in the car, mine will start the car after 10 weeks parked ( c6 )
Offline Lefty
  • Lefty
My clock doesn't work, and don't care about the radio, I isolate the battery every time is park up the car, its started every time ( even after 6 months).
Best
Lefty
79 vette
Offline Kenobe
  • Car: C4 1985
 :hi: I hook mine up to a trickle charger and she's ready to go any time. :therethere:
Offline Hallsy
Bfit,
I bought a red top (optima)too. Great cranking power.
I was thinking about buying the billet aloominum bracket but couldn’t get my head around having a metal plate sitting so close to the terminals.
In regards to a flat battery (as opposed to a completely dead one),wifey bought a couple of those new fangled ciggy packet sized power packs that have the torch,USB ports and car connection. I completely bagged her until I had need to jump a car. Admittedly it was a modern V6 dunnydoor but I hooked it up and it fired the the car right up.
So in my opinion, they’re a great little item to throw in the glovebox (keep them charged though.).
 :cheers:
Offline StephenSLR
those new fangled ciggy packet sized power packs that have the torch, USB ports and car connection.
lol, I just searched ebay for 'Car Jump Starter Booster USB'; you can get them for a dollar including postage, hahaha.
Edit: my mistake, when you go to the page you have to select between a cable and the charger which goes for $60-$70
s
Bfit,
 :cheers:
mate if you have a C3 you can utilise the original clamping set up on the base of the battery.
I'll just print that last comment from Bfit off and frame it, under the title "Bfit says keep it original", allong with a pic of the "Yellow Beastie".
