Author Topic: C5 odometer not showing  (Read 32731 times)
Offline KevT
  • Mood: Always happy
« on: August 08, 2017, 10:08:48 AM »
Hi all, The odometer readout in my 99C5 has disappeared.
It was working fine on Monday but on start up Tuesday the screen remained blank.
Any ideas ?
Re: C5 odometer not showing
« Reply #1 on: August 08, 2017, 03:26:57 PM »
Umm C5 eh!. If you said c4 i may be able to help.
Is it a mechanical or digital (liquid crystal) read out.
84/87 C4's are mechanical, seperate unit that plugs into cluster.
Plug can come loose, but usually the back is deliberately snapped out to allow the metre to he set to a lower number.
Naturally no vettes for sale in Oz have any more than 40 ~ 60K kms on the clock. Sorry sarcasm.
Is everthing else working, esp speedo?
Offline KevT
« Reply #2 on: August 09, 2017, 09:30:14 AM »
Hi VP ....  The readout is liquid crystal display.
If I start running through the DIC info the messages only display briefly before the screen goes black again.
« Reply #3 on: August 09, 2017, 01:05:22 PM »
Kev I'm not ofay with C5, but if its liquid crystal, an educated guess is backlighting, you normally can not easily see LQ without a backlight, this most likely supplied from P'supply on main board. On your cluster you may find a little black hole or orifice that is the light sensor. This drives the display cluster lighting up and down depending upon ambient brightness. If so, get torch, turn on car, display lights up, blank sensor, display dims, shine torch in sensor, display should brighten up (max). If not then the dimming circuitry could be faulty, if all the cluster works except the odometre, then its Mr Google.
Sorry I cant be of more help.
Offline KevT
« Reply #4 on: August 10, 2017, 07:47:02 AM »
Thanks VP .... I'll see what I can find.
« Reply #5 on: August 11, 2017, 04:12:31 PM »
How did U go Kev?  I had a look on Mr Google, not much there, but did see something - question does yours give a read out of fault codes, if so, can you interpret them?. I'm sure the C5 used the better, later OBD11 system.
« Reply #6 on: August 11, 2017, 05:41:23 PM »
He mentioned:
On CorvetteForum, there are numerous references to problems with the display, such as this one:
https://www.corvetteforum.com/forums/c5-general/3694013-dic-display-not-working.html
... and I note that Kev T has posted the same problem on there.
Offline KevT
« Reply #7 on: August 12, 2017, 11:52:43 AM »
Problem solved !
I managed to get hold of a handbook, read through the DIC (driver information centre) and there on page 2-93, 2-94
in Section 3 TRIP I found the answer.
Press the TRIP button and scroll through ..... the odometer shows.
Thanks for the suggestions folks.
« Reply #8 on: August 12, 2017, 12:44:48 PM »
Well that's great, and if nothing else I now know what DIC means, I must admit I was thinking of other forms.
Offline KevT
« Reply #9 on: August 12, 2017, 07:47:57 PM »
That's why I put it in there ....
