Author Topic: Holley 750 Series 4 Barrell ( HP vs Standard 3310 )  (Read 14649 times)
Offline 69CVET
  • Mood: Big Block
  • Car: 1972 Big Block 4 Speed
« on: May 19, 2017, 10:09:40 AM »
With an array of carbies out there ... anyone got some feedback on the High Performance Vs Standard - Holley's ??
Large jump in prices but looking for a good value all around upgrade for the 454 with a mild cam.
Re: Holley 750 Series 4 Barrell ( HP vs Standard 3310 )
« Reply #1 on: May 19, 2017, 01:39:11 PM »
what are you going to use the car for
just drive it, all street use
street and strip
street strip and track.
it all come down to how much fuel you want to use.
Holley`s  ( 650 to 780 DP  centre pivot ) are good old fashion carburettor's . you can tune them very well but they really only work properly in narrow rpm ranges.
say want it to run hard , 4000RPM to 5600 RPM   and set it up for that RPM it will run rich below 3800RPM
Be careful if you contemplate a carby above 780 in a street engine in a Double pump mechanical  set up.
as I remember it the Holley works on 4''Hg across the venture. opening the throttle at low RPM can give you a major hesitation, with a engine tha has to much cam overlap, and larger carby, not a good thing in traffic  around town.
what's wrong with the Rochester , set up correctly they are on of the best on the market.
