Author Topic: C3 parts clearout  (Read 31340 times)
C3 parts clearout
« on: March 23, 2017, 09:14:00 AM »
Power window motors L&R some have new brushes & regreased multiple units $45 each will also fit HK HT HG HQ holden
Power window motor driven gear multiple units $20 each
R/hand power window mech gear quadrant good $40
Upper & lower control arms with shaft & balljoint suit rebuild swapover $40 each or $130 for 4
69 -72 Wiper switch dash panel suit repaint $25
Centre console armrest metal base plate 78-82 $15
Rams horn manifold heat shield suit 79 $10 each
R/hand spindle steering arm power steering $10
72 Wiper motor tested ok ca
Re: C3 parts clearout
« Reply #1 on: March 23, 2017, 06:33:54 PM »
For sale continued power went off this morning
72 Wiper motor tested ok  $50
Wiper drive arms & pivot posts $40
Strut rods large eye  bare $30
Rear axle used removed from rusty trailing arm $50
Rear Hub L/hand $40
Axle flange  used $30
H/brake backing plate used restored L/hand $30
78 - 82 Console plate  has ashtray door & pins earth ring & lighter socket $10
Tie rod tube & clamps used threads not siezed $15 5 available
Front sway bar saddles $10 pair
Lower control arm shaft used $20
Upper control arm shaft used  $20 x 4
AC fan motor new $40
Park brake lever x 2 used $30 each
Clutch push rod pedal- Z shaft $15
Diff parts, sun gears, shafts, crush tube,clutches,plates.Free no hemisphere,housing  or crown wheel & pinion
AC ducts L & R to outer dash vents 78 - 82
79 - 82 Seat hinge $10
79 - 82 seat hinge cover lower x2 $10
79 Dissy Heat shield cover $10
Windscreen surround  stainless strips have been painted black $20 each piece
Ford twin thermo fans as removed from ford fits C3 with modification $40
Power antenna mast & ribbon new $35
R/hand trailing arm new bearings, new bonded brake shoes,all parts sand blasted & powder coated, ready to bolt on car using a poly front bush $500
All parts are pick up only postage extra or can deliver to next club meeting postage will be from 2234 Illawong
Geoff    0417473492    hevyc350@hotmail.com
« Reply #2 on: March 25, 2017, 09:28:38 PM »
Wiper motor is gone
« Reply #3 on: March 27, 2017, 08:24:59 AM »
R/hand power window mech gone
Offline Matt G
  • Car: 1970 Coupe 350 manual.
« Reply #4 on: April 16, 2017, 10:47:33 AM »
Do you have any of the rocker moldings (below the doors) for a 1970 in your list of goodies?  I didn't see any, but thought that I'd ask the question just in case...
« Reply #5 on: April 17, 2017, 10:37:59 AM »
Sorry Matt can't help you with that one will ask my mate down the road has put side pipes on his car car is a 76
« Reply #6 on: April 17, 2017, 02:36:17 PM »
Matt,
I have sent you a PM.
« Reply #7 on: April 17, 2017, 05:16:03 PM »
Nick could have a set of a 72 model
« Reply #8 on: April 19, 2017, 08:55:02 AM »
79 - 82 Horn button blue $15
Tele Column  lock ring black $15
Offline 69CVET
  • Mood: Big Block
  • Car: 1972 Big Block 4 Speed
« Reply #9 on: April 19, 2017, 04:30:29 PM »
Have a set off a 72 but they were on a 72 that originally had pipes so some aluminium blocks have been inserted and finished off flush.
PM can email some pics over
« Reply #10 on: April 20, 2017, 05:05:26 PM »
hi matt g j have a set of rocker moldings lying around if interested?
« Reply #11 on: April 26, 2017, 03:47:00 PM »
hi mat g I sent you email,did you receive ?
« Reply #12 on: April 26, 2017, 10:39:19 PM »
Suggest also using PM.
« Reply #13 on: May 09, 2017, 08:18:04 AM »
350 starter motor $20,  HEI ignition distributor for parts no cap, module RS $10
« Reply #14 on: June 10, 2017, 09:05:51 PM »
 Bump Still got a heap of bits on list 78-82 tacho condition unknown suitable parts or reco  $5
« Reply #15 on: June 10, 2017, 09:11:40 PM »
Free to good home cardboard patterns to fabricate rear wheel arch sheet metal infill panels as fitted in my car. Gets rid of the crappy fit rear wheel arch carpets.Will fit 78 - 82 still allows use of factory cargo blind
Offline Ausrs
« Reply #16 on: July 04, 2017, 06:05:00 PM »
just as a matter of interest do you have either side pieces that sit behind the seats and go from the floor to the roof(the seat belt mount goes through them also )
« Reply #17 on: July 05, 2017, 09:40:25 PM »
They are different from year to year I  don't have any only have a front side console piece for a 70 model
« Reply #18 on: July 05, 2017, 10:07:49 PM »
  what year
Offline Ausrs
« Reply #19 on: July 05, 2017, 10:25:15 PM »
sorry,1975  :cheers:
