Author Topic: Centrelines  (Read 22512 times)
Offline Wono23
  • Mood: Ok
Centrelines
« on: February 06, 2017, 10:27:53 PM »
Hi,
Does anyone have any centrelines for sale?
Re: Centrelines
« Reply #1 on: February 07, 2017, 08:29:56 AM »
Did a job last week on a camaro pretty sure owner said they were  centre line wheels & he was going to change them do you have a picture
Offline Wono23
  • Mood: Ok
Re: Centrelines
« Reply #2 on: February 07, 2017, 03:16:41 PM »
These are the ones.
Re: Centrelines
« Reply #3 on: February 07, 2017, 04:56:38 PM »
Thats exactly what was on Camaro will shoot him an email for you
Offline Wono23
  • Mood: Ok
Re: Centrelines
« Reply #4 on: February 07, 2017, 06:26:50 PM »
Thanks mate.
Offline Wono23
  • Mood: Ok
Re: Centrelines
« Reply #5 on: February 09, 2017, 03:01:30 PM »
Sirfixalot, I received the email and photo's of his Camero.  Problem is it is 14's on the front and 15's on the back.
Found some even nicer ones that are all 14X7's.  Would this look dikkie where the current original wheels are 15's?
Also it is a Holden HQ to WB pattern.
I reckon this would fit.  Would it?
Re: Centrelines
« Reply #6 on: February 09, 2017, 03:10:41 PM »
Im not shaw but I don't think 14s would clear the calipers. Ray
Re: Centrelines
« Reply #7 on: February 09, 2017, 03:16:46 PM »
tight fit, me  think a pointy stick uphill comes to mind. but you never know if you don't try
Offline Wono23
  • Mood: Ok
Re: Centrelines
« Reply #8 on: February 09, 2017, 03:24:14 PM »
I will stick to your advice.  15's it is.  So another question.  Am I on the right track to assume HQ to WB stud patterns would fit at 74' Corvette?
Re: Centrelines
« Reply #9 on: February 09, 2017, 05:05:27 PM »
YES
Re: Centrelines
« Reply #10 on: February 09, 2017, 09:23:11 PM »
Didn't realise he had 14's on the front only noticed the rear tyres were the same as corvette
Offline Wono23
  • Mood: Ok
Re: Centrelines
« Reply #11 on: February 10, 2017, 12:14:59 AM »
All good.  Appreciate you referring him to me.
Thanks everyone for your help.
Re: Centrelines
« Reply #12 on: February 11, 2017, 07:47:10 AM »
I recall many years ago I had a set of 15x8s cragars which are very similar,i bolted them on my 71 and they locked on to the calipers,so I would check fit first and make sure the wheal turns before buying,cheers
Offline Wono23
  • Mood: Ok
Re: Centrelines
« Reply #13 on: February 11, 2017, 06:46:37 PM »
Wow, thanks for letting me know.
I have seen them on Corvettes before.
Re: Centrelines
« Reply #14 on: February 12, 2017, 09:15:30 AM »
yeah I would say it depends on the offset the rim has or a spacer between the rim and the disc
 :bolt: :bolt:
Re: Centrelines
« Reply #15 on: February 13, 2017, 01:34:44 PM »
 :bolt: :bolt:
Rite on
Re: Centrelines
« Reply #16 on: February 15, 2017, 08:51:31 AM »
I've seen a few sets of centrelines on C3's. Not the brake cookers pictured, but the ones below.  All of them appeared very close to the calipers, ie mm to spare
