Author Topic: Diff overhaul  (Read 16412 times)
Offline mention1
Diff overhaul
« on: May 31, 2016, 08:56:04 PM »
Hi everyone,
I've had 2 mechanics now suggest I have a diff overhaul, as it has a whine in it.
I went to the local expert and he said it would cost $1,000 - $1,100. This is with the diff still attached to the car.
I can change oil and brake pads etc but this is a bit beyond me. My question is does this price sound about right?
1979 model. 350ci manual box with 3.36 axle (GV4)
Re: Diff overhaul
« Reply #1 on: May 31, 2016, 09:20:59 PM »
A 3.36 should not whine , in most cases.
 the ratios in the 3.9 /4.11 will whine generally
Having said that, a whine does not mean you need to get is out and rebuilt .
Unfortunately it's difficult to change the oil in a c3 did that is not modified to allow it to be drained.
So it's hard to know if the diff is throwing up some metal
IE on the way out .
Are you saying they can rebuild the diff in the car,
It's just not  an in frame job.
It's a two to three hours job to get the diff out.
To build the diff you can spend a day or two to get it correct .
Im a week into the 12 bolt I'm building at the moment.
If you remove the diff , and take it to a shop a $1000 may get it done but I doubt  it.
Offline rosco
Re: Diff overhaul
« Reply #2 on: June 01, 2016, 07:33:01 AM »
Give award diff a call at Seven Hills very good and have worked on quite few of late.
$1100 sounds a  pretty good price if it's still in the car.
Rosco
Re: Diff overhaul
« Reply #3 on: June 01, 2016, 04:44:28 PM »
if your interested , there is a diff on gumtree for $400 at the moment
