Author Topic: Water temperature  (Read 15035 times)
Offline onya
Water temperature
« on: July 12, 2004, 09:23:07 PM »
On the trip to Lithgow the water temperature was between 68 and 75 as by the readout is this good.
Offline Thunder Kiss
Water temperature
« Reply #1 on: July 13, 2004, 08:55:24 AM »
Onya, you must have a 160 degree F thermostat installed.
I have a 180 degree thermostat and a fan switch that turns my fans on earlier and my car normally sits between 80 - 90 degrees c.  Before I had these fitted the temp was between 89 - 110 degrees c.
Someone told me if you use a 160 degree thermostat the cars computer may not go into closed loop mode.  Anyone have opinions on that?
Water temperature
« Reply #2 on: July 13, 2004, 09:18:39 AM »
... Someone told me if you use a 160 degree thermostat the cars computer may not go into closed loop mode.  Anyone have opinions on that?
Bogus!  A 160 thermostat has no effect once the temp gets above 160 - if your car runs at 185deg it makes no difference if you have a 160 or a 180 thermostat.  A 160 just opens earlier.
I think it goes into closed loop aroung 50deg.  I have a 160 and rune the same temps as Onya.  Before my rebuild it ran at 80-85deg but now runs from 68-78deg (h'way)! ;eek  Shows what a totally clean block can run at.
Offline onya
Water temperature
« Reply #3 on: July 16, 2004, 07:37:12 PM »
Thanks guys, it's just that I'm new to the world of vettes and am learning slowly.;27;29
