Technical Tips
Pre 84
Correct tyre inflation
Topic: Correct tyre inflation (Read 16627 times)
Lefty
Lefty
Four Barrel
April 19, 2015, 07:20:07 AM »
Hi again,
Bought 4 new mickey Thompson sportsman 255/60/15.
There does not not appear to be any information on the correct inflation for road use.
Does anyone have a set on their car and what do they run at.
I'd like to get this right before they bed in too far,
Thanks agin,
Lefty
79 vette
StephenSLR
Fuel Injected
Re: Correct tyre inflation
April 19, 2015, 12:28:38 PM »
Set it to the tyre placard specs you have on your car, of course it may have to vary if they're not the same style of tyre.
You're correct and many don't realise tyre pressure maximums are just that; the maximum for that tyre; the correct pressure depends on the car and how you drive it.
s
Listen to my band here:
http://www.reverbnation.com/LYCANTHIA
Miss Independent
Tri Powered
Mood: Girls just wanna have fun
April 19, 2015, 02:44:38 PM »
http://www.corvetteforum.com/forums/c3-tech-performance/3047994-anybody-use-mickey-thompson-et-street-radials-on-the-street.html
This should help you out Lefty
MY081
I'm here. Woo Hoo! :)
Fuel Injected
Pleb
Reply #3 on:
April 19, 2015, 04:05:57 PM »
I have that tyre on my car and run 36psi on the road and 42psi on the track . Maybe 2psi less in the rear is ok ,Ray
Lefty
Lefty
Four Barrel
Reply #4 on:
April 19, 2015, 07:43:08 PM »
Many thanks for the repos ses,
I'll had them at 36 today and the ride was a bit abrupt,
Dropped to 33 and will tas out over the next few weeks,
Looking to maximise tyre life and not over or under inflate,
Cheers,
Lefty
79 vette
Don't talk of dust and roses
Global Moderator
Two one thousands
Mood: Honey reinforced
Car: Yes
Reply #5 on:
April 19, 2015, 09:50:18 PM »
Tyre pressure depends on lots of car
Google tyre wear caused by wrong inflation
Watch your tyres and you will soon know what pressures work with the tyres and your car .
Get a wheel alignment as well
Ps start with 81s recommendations
Lefty
Lefty
Four Barrel
Reply #6 on:
April 20, 2015, 07:29:18 AM »
Thanks mr B Fit
Good advice and note monitor
I did get a wheel alignment after the accident and will see if that was any good
Otherwise off the heasemans
Lefty
79 vette
Technical Tips
Pre 84
