Author Topic: C2-C3 Front coil springs  (Read 47223 times)
Offline anychevy
  • Car: 66 convertible
« on: April 07, 2014, 04:53:56 PM »
Has anyone had any success with Holden (HQ-WB) springs in a (small block) C2 or C3 ?
Re: C2-C3 Front coil springs
« Reply #1 on: April 07, 2014, 06:32:13 PM »
Mate
I have a set of standard springs out of a 70 model
If you wnt something to use to compare to Holden springs
Offline anychevy
« Reply #2 on: April 07, 2014, 07:20:18 PM »
Mate
That would be great, thanks
Can you PM me your number please
Offline craigh
« Reply #3 on: April 07, 2014, 08:09:33 PM »
i have some 1971 sb stock springs and a set of pedders red lowered out of an hj that i can take some photos of tomorrow
Offline anychevy
« Reply #4 on: April 08, 2014, 07:29:23 AM »
Thanks Craig
What springs did you fit in your vette ?
« Reply #5 on: April 08, 2014, 07:56:02 AM »
I used standard lowered HQ springs in my 77.  Fulcrum measured my old ones and said they are the same.
I'd use them again.
 :cheers:
Offline craigh
« Reply #6 on: April 08, 2014, 11:54:46 AM »
Hi Dave
Here is the stock 71 small block spring next to a Pedders HD lowered HQ-HJ (non RTS) spring.
Exact same diameter etc.
In my 71 I used semi coil overs as I wanted to set height exactly and have more control.
Build Thread
Craig
Offline anychevy
« Reply #7 on: April 08, 2014, 12:46:08 PM »
Do you remember what brand and how low ?
Offline anychevy
« Reply #8 on: April 08, 2014, 12:48:39 PM »
Thanks Craig
So they'll fit, but what about ride and ride height ?
What else have you guys tried ?
Offline craigh
« Reply #9 on: April 08, 2014, 12:52:36 PM »
Complete ride height control
Offline craigh
« Reply #10 on: April 08, 2014, 12:54:16 PM »
The semi coilovers from Speed Direct let you choose from a number of coil stengths as well as the QA1 dampers having adjustable rebound and compression control.
Make it whatever height and as soft of hard as you like.
Offline anychevy
« Reply #11 on: April 08, 2014, 01:38:56 PM »
I'm trying to keep a stock appearance, but that's a real nice setup. :thumb:
« Reply #12 on: April 08, 2014, 08:49:49 PM »
So lads has anyone actually said what the ride height at the front should / is ?
I think we should have a benchmark
My front has sagged over the last 6  months (since refitted motor) and I'm thinking of getting a new set of front springs. the point being what is in it now and what standard ride height be against say Pedders HD lowered HQ-HJ (non RTS) spring. ?
Offline anychevy
« Reply #13 on: April 08, 2014, 09:58:24 PM »
To add to the confusion, Pedders list this as a spring for 63-82
http://www.pedders.com.au/search/node/7152  :huh:
A different spring again
« Reply #14 on: April 09, 2014, 07:32:47 AM »
by the looks of the info on the Pedders site its a multy fit spring
« Reply #15 on: April 09, 2014, 08:18:35 AM »
Can't remember what brand.  You can give Fulcrum a call - http://www.fulcrumsuspensions.com.au/
The wheel arch was same height as the tyre.  They did make the front end pretty stiff!
Offline anychevy
« Reply #16 on: April 10, 2014, 07:43:36 AM »
Thanks for that
I picked up a used pair from Bfit (thanks again Bob) I'll clean them up and try them first.
I can always cut a little off if too high.
« Reply #17 on: April 10, 2014, 08:15:38 AM »
I cut only 1/2 a coil off my 71 stock spring and they are too low!  :tears:
Mind you.....you can't expect much from 40yr old springs.
Offline anychevy
« Reply #18 on: April 10, 2014, 05:12:07 PM »
:eek: I think we've all been there, if we're honest
This is a good article on how (and how much) to cut a coil spring
http://www.chevyhiperformance.com/techarticles/89858_chevrolet_lowering/
« Reply #19 on: April 13, 2014, 05:01:05 PM »
Lads I have 335 - 340 mm from centre line of wheel to top of guard can someone tell me what a standard set of stock height springs would be ? Cause I reckon my front springs have sagged as I'm scrubbing out on things I never used to... No I haven't put on fooken Weight  :grin:
