Technical Tips
Engines - Carbies - Exhausts - Dissys
1971 Twin Point Dizzy Replacement
Topic: 1971 Twin Point Dizzy Replacement (Read 12429 times)
77CVT
Fuel Injected
November 18, 2013, 11:17:57 AM »
I have a lot of play (in every direction) in my 71’s twin point dizzy……which may explain my carb backfire issues (hopefully). Did a quick search on HEI tach drive dizzy’s and there seems to be a huge variation in price.
Has anyone purchased a replacement or have any opinions on the ones out there. I’m not going to spend $450 as some of the top end priced ones are but saw this at Ecklers -
http://www.ecklerscorvette.com/corvette-hei-distributor-conversion-1962-1975.html
Also -
http://www.winnerscircleautoparts.com/chevyheidistributortachdriveredcap.aspx
Any suggestions?
Don't talk of dust and roses
Global Moderator
Two one thousands
Mood: Honey reinforced
Car: Yes
Re: 1971 Twin Point Dizzy Replacement
November 18, 2013, 12:18:14 PM »
Mate i went with a MSD and a 6al controller
works great
77CVT
Fuel Injected
November 19, 2013, 09:25:52 AM »
hmmm $450+ for the dizzy and $280 for the controller...... I would hope it works great! Bit out of my range.
Global Moderator
Two one thousands
Car: Yes
Reply #3 on:
November 19, 2013, 09:29:29 AM »
I have not rebuilt a distributor for a long time but I would think you would be able to get a set of bushes for the dissy and get it back to good running order
I do like the MSD dissy and controller with the added advantage of a rev limiter
77CVT
Fuel Injected
Reply #4 on:
November 19, 2013, 12:43:56 PM »
You are right but I'd rather burn a twin point dizzy!!
Your setup is ideal but I'm not prepared to spend that much on a car I unfortunately do not drive enough!
I'll prob go with the Winners Circle one but with all the cheap ones out there I am unsure if they are Chinese built or not.
Global Moderator
Two one thousands
Car: Yes
Reply #5 on:
November 19, 2013, 01:48:12 PM »
I was never keen on twin points distributors
I could not see the advantage in 8 lob versions and the
4 lob variety worked to a degree butt were a pain in the rear to keep the timing correct.
Technical Tips
