Author Topic: 6 speed Magnum in to C3  (Read 31066 times)
« on: June 04, 2012, 03:13:36 PM »
A few photos of mount  to fit Tremec 6 Speed magnum in to early C3
end view of plate the welds to chassis
chassis mount on cross member
Mount weld in original  position  as original  cross member
Trans mount  is positioned 25 mm forward and 20mm lower that the origin mount on the cross member
It a pears that a transmission guard will be needed as the transmission will be lower  that the  bottom of the cross member .
Andy
I think I am on top of the swap
keep you posted
Bift
« Reply #1 on: June 04, 2012, 09:19:26 PM »
Will look like a factory x-member to the untrained eye.
Subtle changes that incorporate improvements has got to be good
« Reply #2 on: June 04, 2012, 10:53:37 PM »
Good job!
« Reply #3 on: June 18, 2012, 10:48:16 AM »
the process continues
Gear  box as it arrived
Trany with Bell housing
I have the box
First problem is the speedo drive points the cable straight at the exhaust.
I am not in the process of shorting the drive out of the box,
  to allow the use of a 90 deg  drive .
With the cable drive as supplied the 90 Deg cable drive will not fit
It interferes with the mounting  pad of the transmission.
Bift
« Reply #4 on: June 18, 2012, 06:07:16 PM »
Hey Rob,
Doesn't the new 6 speed box have the alternative to run electrical speedO as well as the traditional mechanical?
« Reply #5 on: June 18, 2012, 06:43:09 PM »
Yes jethro it has both
I want to run the mechanical drive to keep it simple
I will post photos tomorrow of the modified drive to move the 90 deg cable drive up closer to the box
« Reply #6 on: June 18, 2012, 06:47:58 PM »
Looking good Rob
« Reply #7 on: June 19, 2012, 09:01:54 AM »
Speedo drive  problems solved
Original speedo drive as supplied
To get this to fit I have to Cut 16mm of the end of the mounting pad.
TO use a cable straight on the speedo drive would run the cable straight at the exhaust
I modified the drive as  shown to get more clearance
Speedo drive 15mm shortened  to move angle drive up closer to gear box for  clearance to exhaust
Modified drive fitted to gead box
« Reply #8 on: June 21, 2012, 11:13:47 AM »
Trail fit magnum to 76 auto body
Trans in  position
I had to cut the tunnel to get the box up to the correct center line
the section removed  is the area  where the original auto shifter  was mounted .
this section  protrudes down towards the gear box about 32mm.
the hole will serve as the shifter position.
 in the photo above  you can see the trans mount  the bottom of the mount is 10mm below  a lone taken across the bottom of the chassis.
this photo show  gear box  sitting at center line of original box
there is just adequate clearance.
note the top of the shifter area is at an angle  that is standard  in the design of the gear box its about 17 degs to the left side.
this is a 76 auto body  I would think there will be less room in a 70 model manual body I will know in a few months if that is true.
the photos  could be better but that is how it is  when you take them with a phone in the middle of the night
« Reply #9 on: August 27, 2012, 10:55:15 AM »
I am finding time to work on this again
modifying the transmission mount
 the tremec  magnum  rear mount is 3.1"  to the  center line of the  out put shaft
I have machined  this to  2.785"
the Mounting  pad  is  now 5/8"  think at the  mounting  bolt hole
I  removed 0.225" ( 5.715 mm )
the mounting pad on  box comes set up for chev and ford
I machine the  the excess off
« Reply #10 on: August 27, 2012, 12:55:39 PM »
Handy things those mills.
nice work, keep us posted :thumb:
Hey I got a question for you..
I was looking at your modified speedo drive, how did you shorten it, I see heat marks, cut and tig?
« Reply #11 on: August 27, 2012, 02:30:31 PM »
Quote from: Camo link=topic=9256.msg1045943540#msg1045943540
    posted on 27-8-2012 at 02:25 PM
I bored the threaded section out to 0.625" Dia
then parted it off.
Then machined the OD of remainder to accept the threaded part with 0.001 clearance  and leaving a shoulder  of 0.236" (6mm)
I silvered solders the two together
using no. 2 flux and 55% silver solder.
I can do you a drawing if you are not sure of what I have described
« Reply #12 on: August 27, 2012, 04:24:33 PM »
Quote from: Bfit link=topic=9256.msg1045943541#msg1045943541
then parted it off.
No that's fine thanks, I got it.  Was just curious.  Nice job. :thumb:
