Author Topic: Question to chrome bumper owners  (Read 8656 times)
« on: July 29, 2008, 04:44:20 PM »
I need to know what this switch does!
Under the dash - in between the two vacuum over ride pull down knobs, there is a two way switch with a black knob on it. What's it for??
While on topic, why is there two vacuum over ride knobs? On my 76 there was only one. Is the second for the wipe door?
I'm in the process of redoing my Vacuum system as its not working properly so I cannot ID exactly what these switches/levers do! I've tried pulling and switching, but they do nothing at the moment! I've replaced all tree actuators and now it looks like I'll be replacing every hose and then see what happens.
« Reply #1 on: July 29, 2008, 05:06:32 PM »
The knob in the middle is a rotary action on/off electrical switch. It allows you to stop the electric wipers in mid operation so that you can maintain or replace them.
When you put the normal wiper switch into the "off" position, the wipers automatically park themselves down in the bay under the wiper door and the door closes.
So, to work on the wiper blades, switch on wipers as normal and then use that rotary switch to interrupt the wipers.
Don't forget to switch it back again when finished otherwise you'll think your wipers have gone on the fritz next time you need to use them.
One vacuum switch manually opens the wiper door, the other pops up the headlights. Naturally, the vacuum system needs to have vacuum in it at the time for either switch to be effective.
« Reply #2 on: July 29, 2008, 05:39:22 PM »
Awesome.
Thanks for the info. Much appreciated.
I guessed the second vacuum might have been for the wiper door, but I would have never guessed what the switch was for!
« Reply #3 on: July 29, 2008, 09:53:39 PM »
That should be fun...not ;41
good luck with it
« Reply #4 on: July 30, 2008, 06:20:22 AM »
good luck with it
I've got so many things on the go - I've postponed the vacuum till I finish rebuilding the front and rear end. Then I'll go back to the Vacuum. Give me another week or so! Time is rare these days!
« Reply #5 on: July 30, 2008, 08:48:12 AM »
get a vacuam gauge...worth their weight in gold....pump up and check each hose in sections....generally where it loses pressure is where the problem is.
« Reply #6 on: July 30, 2008, 03:23:54 PM »
I've seen the vacuum gauges on other forums and they look handy.
I was going to measure and buy all the hoses off the roll, but I decided I couldn't be bothered so I just added a complete hose kit to an order I was making from Willcox.
It won't hurt replacing them all. I have a feeling it was just the hoses as they are a bit perished in places and that can be detrimental to the vacuum.
« Reply #7 on: July 30, 2008, 05:54:31 PM »
were is the best place to buy a vacume gauge,cause i rang up toolies and there cheapest was $400,way over the top just for that job?
« Reply #8 on: July 30, 2008, 06:25:24 PM »
« Reply #9 on: July 30, 2008, 07:11:00 PM »
I bought a pretty good one from Repco for around $70. It does vacuum and pressure (e.g. for fuel pump).
« Reply #10 on: July 30, 2008, 08:06:47 PM »
thanks nifty,i just bought that one on ebay,at that price its worth a go,will let you know how it works as i am have problems with my lights and wiper door not opening?
« Reply #11 on: July 31, 2008, 12:58:39 AM »
doesnt everyone with a c3 have the same problem eventually?
« Reply #12 on: July 31, 2008, 07:19:40 PM »
No!  ;41 not any more! Vacuum sucks!!!! Go electric!!!
« Reply #13 on: July 31, 2008, 07:51:18 PM »
thats takeing the easy road;29
