Author Topic: larger gas tank ?  (Read 11343 times)
larger gas tank ?
« on: July 23, 2007, 07:19:33 PM »
I've got a 120L aluminium tank! But I've had to take out the spare & assembly! I could show you pix but the photogallery wont let me in to download?????
larger gas tank ?
« Reply #1 on: July 24, 2007, 10:08:27 PM »
Originally posted by 69 DIRTY RAT
................... I could show you pix but the photogallery wont let me in to download?????
Whats the problem Andy?  Password?
Offline MADVET
larger gas tank ?
« Reply #2 on: July 24, 2007, 10:25:43 PM »
Andy that 120litre tank would just be your surge tank wouldn't it?
The main tank would be following close behind.............on the back of a truck;53
NOW WE'RE TORQUING!
Offline L71
  • 69 L89 Auto
  • Mood: :-)
larger gas tank ?
« Reply #3 on: July 26, 2007, 07:02:31 PM »
Ive also had a 110litre tank made up by a localguy down my way , if andy,s guy is busy this guy can usually knock one up in a couple weeks , you will have give some dimensions as mine and andy,s both have had to remove our spare wheels, because were running 18 inch wheels,& other mods, so the dimensions my guy has would not fit your car,
you can go a lot larger than stock and still keep your spare,
I,m away for work till friday ,if you need his details give us a call on the weekend 0407 012359
larger gas tank ?
« Reply #4 on: July 28, 2007, 02:57:29 PM »
Here's some pix, the guy I use will be busy for a while, surely there would be an aluminium guy up your way that could do the job?
back
back
front of tank>out
larger gas tank ?
« Reply #5 on: July 31, 2007, 08:54:30 PM »
The guy that makes the tank will have to fit an aftermarket sender to suit!
larger gas tank ?
« Reply #6 on: August 01, 2007, 07:20:45 AM »
Hey Andy,
Im not that good with maths, but if im right, uhmm.,.... thats like 120L x $1.50 per litre (premium)= $ 180
Holly crap........ :grr
Thats a lot of dosh
M;36
larger gas tank ?
« Reply #7 on: August 01, 2007, 11:23:36 PM »
Originally posted by 69VETTE
Hey Andy,
Thats a lot of dosh
M;36
I only half fill her, its only on longer trips would I fill it! But hey when you use a shop-a-docket you get 4c off!
Offline L71
  • 69 L89 Auto
  • Mood: :-)
larger gas tank ?
« Reply #8 on: January 27, 2008, 09:41:57 PM »
My new mobile no is 0418 111525   sory i accidently put my old work number instead
larger gas tank ?
« Reply #9 on: April 05, 2008, 01:53:32 PM »
Looking good Mick.  Changed ya link so that the pictures show up here.
Keep us posted.
larger gas tank ?
« Reply #10 on: April 05, 2008, 02:26:22 PM »
looks good mick:xcant wiat to see it in;)
larger gas tank ?
« Reply #11 on: April 05, 2008, 09:43:55 PM »
How many liters?
larger gas tank ?
« Reply #12 on: May 09, 2008, 11:09:31 PM »
Is it the sender unit? I still havent put the proper sender unit in mine yet ,mine reads full when only half full.
larger gas tank ?
« Reply #13 on: May 10, 2008, 12:05:03 AM »
Sounds like you need a different sender.
The sender is a variable resistor that's connected to a float arm. As the level in the tank changes, so does the resistance of the sender, thereby changing the voltage or current (depending on the system) measured by the gauge.
The sender's resistance varies in proportion to the float arm's position in the tank -- that is, half full should cause half scale deflection on the meter.
You may be able to compensate with an additional resistor. Suggest you discuss this with an autosparky.
larger gas tank ?
« Reply #14 on: May 10, 2008, 01:32:08 AM »
Spoke to Mick on the phone.  It was doing this with the old sender after some dash work was done.  I'm betting on the earth wire to the gauge.  Without this connection you will get faulty readings.
See diagram below
larger gas tank ?
« Reply #15 on: May 11, 2008, 10:42:31 PM »
From memory the tank resistor is 0 ohms when empty & about 40 ohms when full
Offline reserved
larger gas tank ?
« Reply #16 on: May 11, 2008, 11:32:01 PM »
;45
If this is correct a dirty earthing connection could give a resistance so as the gauge does not read empty, try wriggling the earth conections at the point where the gauge is earthed  and see if the gauge varies.
:bold
larger gas tank ?
« Reply #17 on: June 22, 2008, 01:45:52 PM »
do you get tyre rub at all?:23
larger gas tank ?
« Reply #18 on: June 22, 2008, 03:04:44 PM »
Originally posted by mick
Filled my tank today 110 litres !!!!!
;42
Great result. By my calculation that's about a 46% increase in capacity over the standard tank.
