Author Topic: Bled new Wilwood brakes but still spongy pedal  (Read 81700 times)
Offline jimandemma
« on: February 26, 2018, 05:23:09 PM »
Hi all, I have fitted new Wilwood 4 pot calipers, discs and braided lines to my 75 C3. I tried bleeding the system with a hand pump to no avail, just kept pumping through air bubbles. The master cylinder has not run dry and currently have passed around a liter and a half through the system. Tried again today using the pump the pedal and hold, crack the nipple and tighten. No air appears to be in the system now but the pedal is still spongy to the floor. Can't work it out, can someone offer some advice. I have done bleeding before on the car with no problems, this has me stumped.
Cheers, Jim
« Reply #1 on: February 26, 2018, 05:31:27 PM »
tell me about it Jim
I spent to days last week doing the same thing .
and could not get a peddle .
 Are you starting at the  further  calliper first and working back to the closest
Did you bench  bleed the master cylinder
try opening the farther bleeder  and just let it gravity free for a few  hours, that's how I had to do it last time to  clear all the air.
then work towards the master cylinder.
if all else fails get a  set of quick bleeders
 This time I what and bought a vacuum  bleeder, sorted it out in 20 minuets
Offline jimandemma
« Reply #2 on: February 26, 2018, 05:50:53 PM »
Yes, started at furthest rear, inside and outside top nipples and worked my way forward to the caliper closest to the master cylinder. Have not bled the master because it hasn't run dry. Vacuum bleeder is not helping and draws air, where pedal pumping appears better with solid fluid when cracking the nipple. I have done this 3 times today in succession with still no pedal.
Offline Shane Finn
« Reply #3 on: February 26, 2018, 10:07:17 PM »
You haven't mentioned if you have new pads as well.
Either way, check that the pads are flat, true and properly seated. If they are even slightly cocked, the caliper will be able to distort the pad backing plate to conform to the disk but the extra pedal travel to do so will be long, soft and squishy.
This is a common racing problem I've had where the pads get tapered by use.
2001 Z06, Torch Red
Offline jimandemma
« Reply #4 on: February 27, 2018, 06:10:54 AM »
Yes, pads are new and appear properly seated and true to the disc
« Reply #5 on: February 27, 2018, 01:15:23 PM »
If you have rubber lines, clamp all 4.  If the pedal is still soft = master cylinder.
If it is hard, get a helper and release each corner one at a time.  The pedal should only move a small amount if it is ok.  Re-clamp and do the next corner - if a corner you release moves the pedal a lot then that is your culprit.
« Reply #6 on: February 27, 2018, 03:38:01 PM »
if you have a second person .
crack the fitting at the master cylinder and then get the helper to slowing depress the brake  see if any bubbles are present start with the rear brake line first  then the front.
Offline jimandemma
« Reply #7 on: February 27, 2018, 06:06:54 PM »
OK, tried gravity bleeding to no avail. Tried the helper depressing the pedal again and now got a whistle from underneath when cracking the nipple and brake warning light came on. Tried again, whistle gone but brake warning light on. Fluids are normal front and rear of master cylinder. Starting to give me the sh#ts. Pedal is spongy to an inch off the floor. Pumping does nothing to the height of the pedal, hold, crack the nipple, no bubbles, pedal to floor, tighten nipple. No change with all 4 corners. I'll try the master next, cracking the lines.
« Reply #8 on: February 27, 2018, 06:12:17 PM »
Remove the switch sender and reset the valve,
That can be the problem, I have not seen it but I have read  that others have had this as the problem
Offline jimandemma
« Reply #9 on: February 27, 2018, 06:30:59 PM »
No worries, will try tomorrow.
Offline jimandemma
« Reply #10 on: February 28, 2018, 05:51:28 PM »
Cracked the lines at the master cylinder and a few bubbles came out of the front line. Reset the proportioning valve cylinder and have no brake warning light now. Bled brakes again with some air coming out of the front calipers inner nipples. Did all this with the master cylinder line on and clamped. Rear boot sucks down but front doesn't. No difference in pedal!!! I give up!! Have to get someone out to fix this as I'm beyond my capabilities
Offline jimandemma
« Reply #11 on: February 28, 2018, 05:52:48 PM »
Correction, master cylinder cap on and clamped.
« Reply #12 on: February 28, 2018, 08:38:43 PM »
Don’t give up if it worked before you changed calipers then it will work again.
May be some one has a pressure bleeder.
Members anyone  have one.
Ps what Sudurb are you in
Offline jimandemma
« Reply #13 on: February 28, 2018, 09:48:24 PM »
North Arm Cove, 45km north of Newcastle. I'll buy a pressure bleeder and try that Friday
« Reply #14 on: February 28, 2018, 10:49:08 PM »
I suspect you still have air in the front half , hence it’s not pulling the oil down in that chamber.
Do you have assess to gear to make a brake line.
Offline jimandemma
« Reply #15 on: March 01, 2018, 09:48:38 AM »
I have access to gear to make a brake line. It's pulling the fluid down in the front cylinder but not the front boot on the cap as the rear.
« Reply #16 on: March 01, 2018, 11:16:48 AM »
not sure what you mean by the above
BFit
Offline jimandemma
« Reply #17 on: March 01, 2018, 11:55:28 AM »
Inside the master cylinder cap there are 2 expandable rubber boots that stop fluid swishing around when the level is down. When using the pump the pedal method bleeding the rear calipers, the rear master cylinder cap boot will get sucked down with the level bled from that rear section of the master cylinder. When bleeding the fronts, the front master cylinder cap boot does not expand with the fluid drop in the front section. I have also been bleeding with the engine running, so going to try again with the engine off, no booster.
« Reply #18 on: March 01, 2018, 01:15:59 PM »
Seriously, try and clamp all 4 lines.  If you pedal is hard then it's not the master cylinder.  Granted, I've only ever done this on cars with a booster but should produce the same result.
« Reply #19 on: March 01, 2018, 02:48:18 PM »
If you can make up a  line  with about enough tubing  that you can loop over the top and back into the reservoir below the fluid then you can see what’s  happening
